I just connected my new dewalt 20 gallon compressor, oil lubed and after plugin it in for about ten minutes it was only about a quarter full. I shut it off just in case but that seems very slow to fill up. What is a reasonable expectation in time?
Defective pump
Bump after four months of avoiding this issue with the compressor. It's not leaking bc it maintains pressure but it doesn't fill up nor does the motor stop. I'm dumbfounded.
I'm dumbfounded you would keep a likely defective compressor over four months without returning it.
I'm dumbfounded you would keep a likely defective compressor over four months without returning it. Sounds like the pump is either bad, or it's bleeding off air after a certain pressure. Do yourself a favor, return it to Sears before its too late...
Looking at Sears.com it look to have a 12 month warranty. I am calling them later today. Worse case scenario, repair the pump.
Limited Warranty
DEWALT Industrial Tools are warranted from date of purchase.
2 Year – Limited warranty on oil-lubricated air compressor
pumps.
1 Year – Limited warranty on all other air compressor
components. This warranty is not transferable to
subsequent owners.
DEWALT will repair or replace, without charge, at DEWALT’s
option, any defects due to faulty materials or workmanship.
For further detail of warranty coverage and warranty repair
information, call 1-(888)-895-4549 or visit dewalt.com.
if they give you any flack, buy another one identical and return the defective one for refund.
even if had run perfect for 7 months and then failed, they still ethically owe you a new (not refurb) compressor.
Dewalt owes him a new (or repaired) compressor, not Sears.
The warranty is through the manufacturer. Sears and other retailers are just nice enough to offer a return policy for people who change their mind or have problems right out of the box.
If the OP wanted Sears to handle the issue, he should have returned it right away.
The warranty is through Dewalt and I believe that's who the OP should contact, just like the Dewalt manual says to do.
