VISE REPAIR 101 all vise repairs, lubricants, sources for parts and the tricks to fix
vertguy
SE WI
With some heat and an impact screw driver, 3 of 4 jaw screws were successfully removed. The last one is being stubborn and most of the head material was carved away by the impact, so I need to venture out tomorrow and find some left hand drill bits.
D
drivesitfar
Vert: if you don't want to buy a left handed drill bit you could probably hand drill off the head of the last screw and after the jaw is removed just use a vise grip to pull the rest of the screw out. did you buy a Snap on impact screw driver or did you have one in a drawer?
you are almost there and best of luck.
nine4gmc
Dallas
I just used a standard drill bit, a size or two smaller than suggested for tap size and drilled the center of the bolt out. The remaining bolt casing left in the threads came out with a pick tool, then I just ran the suggested tap size drill bit in, tapped it to clean the threads and was done.
That, after trying to use a ez-bolt out on another one and took me forever, I broke two ez-outs...:mad:
Keep it simple!
EDITED: Drives, you up late or early? :lol:
D
drivesitfar
Nines: up early i guess for now because sick old furry friend is on her last days and woke me up a few hours ago. i usually get up at 4am anyway so might as well stay up and get some GJ posts in before the day gets busy.
nice idea on your jaw screw fix and personally if they are on there straight and true i'd leave them alone to work another 50-100 years without messing with the screws.
ALL: so i have one of my favorite vises that is a Wilton Baby Bullet that has a power arm and a clamp. it works great but the primer coat and dull jaws and main screw hub need a little color and shining up. so my question to you all is what color might look best on a small vise i use almost daily? i am not thinking of using my standard boiled linseed oil because i have my hand all over this vise when i more it around.
here are my color choices i'm thinking of and would like to see others that have pictures or ideas to post. i know it's my vise and my color so i'll probably pick my favorite unless i see something different. it's too small and i don't have the talent that Ritzblitz's sister had when she painted his Reed 1C. i'm thinking one color with painted letters and shiny steel jaws and handle.
1) John Deere Green and Yellow
2) Black and gold
3) Wilton green with white or black letters
4) Arrest me red with white or black letters
5) Blue and white
6) Yellow
7) Orange
what are your favorites and can you post your vise or one you like with your comments?
have a great day all
vertguy
SE WI
Drivesitfar: I had a HF impact screwdriver from a couple brake jobs on the Hondas for removing those pesky factory rotor retaining screws... and this is probably the only other time I have needed it. Good timing on the paint question as that is already running through my mind for this one. I am probably sticking with something in a gray and or hammertone to keep with the theme of the rest of the garage. This one will be bench mounted and put into uses, so it will need a durable finish.
Good points on KISS as I was already thinking about simply drilling the head out. And yeah, in hindsight the screws and jaws could have just been left alone. But my ****/perfectionist mindset kicked in as always, so the jaws had to come off. All part of the fun!!
McBrownie
Cleveland, OH
Drives,
I used one of those small cans of lacquer from a hobby store on my 9300 at the beginning of the football season to help my Browns. It got them to 7-9, which is the best they have done in a long time. Maybe I'll paint the whole thing orange and see if they get to 14-2 next year.
The great thing about the hobby store paint is that it comes in all sorts of colors. I would pick something unique - metal flake. We've seen enough verde green. ;) Since it is lacquer it drys fast and can be covered with my favorite - Rustoleum Crystal Clear enamel. It is wearing really well. Better than the Rustoleum hammered that used to be on there.
View media item 42668
wrenchguy
NW Indiana
Make it the best days or hours of its life. Been there done it several times.
McBrownie
Cleveland, OH
I completely missed that in the original post We lost one a little over a year ago. Here she is with some guinea pigs that we were babysitting. When she was healthy, she wanted to eat them. But, during her last days, she seemed to like being around them and vice-versa. She had 13 good years.
View media item 46710
vertguy
SE WI
Success!! I ended up just drilling off the screw head leaving only a small amount of material and the jaw popped right off after a couple hammer taps. As expected, finding a screw with a small enough head to fit in the jaws was not feasible at my local stores. So I picked up the correct length 10-32 SS screws and will just run them down to the correct size with a file with them in the DP. My POS files don't like cutting stainless, so a good excuse to upgrade.
nine4gmc
Dallas
Drives, sorry to hear about the furry friend. My thoughts are with you and your friend, I hope y'all had some good times.
My mom had a Chihuahua named Elvis that lived a few days short of 19yrs old and the crazy thing, he died the same day the real Elvis died but this year. :(
I have a Shih Tzu that will be 9 in Feb, my baby, I will be a nut case when she goes...
Now, back to your regular programming. Glad you got it vertguy!
Lu-Max
Also sorry to hear about your pooch Drives. My pups are my constant companions, hate to think about losing them. But they are now 12 1/2 years old and I have to begin to acdept it, but it just makes our time now that much better.
As a change of pace, I recently used Testors "Lime Ice" lacquer spray on a project. It turned out a nice metallic, green-apple color that is really appealing. Nice to mix it up once in a while and get away from black, blue &/or red.
Blue Frog
Lynn Haven, FL
Love the color on the Wilton - Think I'll paint mine the same. :thumbup:
Thrumcap
Nova Scotia
Here's some reference breakdown shots of a Record No. 83 Engineer's vise.
Final paint job to come...
Thrumcap
:canada2:
CoyoteKyle
KCMO
Can anyone point me in the right direction to find replacement jaw inserts for this Lakeside vise? I received it for Xmas and would like to get it into working condition.
The one you showed looks decent enough: Is one broken or missing? if so, contact Dr. Scott on the Vices thread you can send him one and get it duped.
CoyoteKyle
KCMO
One jaw insert is gone. You can see it in the 3rd pic. You can tell the person who had this before me used without it for a while. I also noticed someone on the vises of GJ thread had restored the same Lakeside in December so I have a PM off to him.
Tritonus
That big *** bolt that holds the swivel to the base. The one with the screw driver head, where people slid a metal in the slot and used a vise grips to turn it. How do repair the threads on that bolt. The threads don't seem standard.
Are you talking about someone else's vise post? Or is this a new question? If new, a picture is worth a thousand words... :dunno:
GETRIDAONE
Auburn, GA
I decided to remove the swivel pin from my 6" American Scale. I first tried a 3/8 Jack Screw and I noticed it was pushing the jaw and body apart. The pin was stuck in the top jaw portion and free in the main body. I wasn't liking that so out come the old pipe clamps. There is only a small ridge of metal on the interlocking grooves inside so I didn't want to put to much pressure on it. You can see from the pictures what I rigged up to keep the two pieces together.
I moved up to a 1/2 jack screw and tightened until I thought something was going to break. I gave the pin a tap on the side and it just came out with a crack & pop !! Free Free Now I have to work the jaw back & forth to get all the rust out of it.
McBrownie
Cleveland, OH
Get, that is a great explanation and good idea with the pipe clamps. :thumbup:
D
drivesitfar
Wrench, McB, Lu-Max and Nines: thanks for the best wishes for my furry friend and she seems to be feeling a bit better and not throwing up 3 times a day the last couple days. Mirry is actually a tortoise shell calico cat and about 9 years old. the vet operated on her 6 years ago and then a month later wanted to charge another $1,000 to do the same operation. we declined and the nice Dr. said we should euphonize her and she would do that for no charge. except for the last month she has been a great addition to our family and hopefully she'll last a bit longer. we've had several cats and dogs over the years raising our 5 kids and still haven't been able to replace our last dog named Taffy since she passed in 2008. other than our grand god we've been dog less too long so that will be our next one when Mirry moves on. if my daughter ever moves and needs a home for the grand dog he can stay here in a minute. the dog craps in the high weeds over behind our fence.
Vert: did you get your vise back together after customizing some new screws?
Thrumcap: nice way to display your vise. is it back together and was it hard taking that apart with the closed end on the dynamic?
Get: the strap hook threw me off for a minute and then i saw your genius way of putting the pipe clamps on it while you reefed on it. success is great when it's your own plan and congrats. also i would have never thought to do that so thanks for teaching me (us) that.
balane
I love those last photos. You won't ever find my Riley far from a tennis ball. My arm is sore pretty much all day from throwing it.
vertguy
SE WI
Any tips for cleaning up the anvil area on my Wilton? I assume on the flat surface a hand file seems appropriate, but not so sure on the best way to remove/reduce some of the dings along the edges??
belt sander is what I generally use for that.
balane
I agree, belt sanders are best for that. If you don't have one and intend on purchasing one get the widest one you can afford. You want the belt to cover the entire anvil so you get a smooth, level surface.
vertguy
SE WI
Great idea. Always wanted to pick up a belt sander and now I have a good excuse. The width should not be a huge issue with this 3 inch Wilton, but thinking ahead I will get a larger one. Now onto some online searching. Thanks once again to GJ for spending my money :lol:
Any recommendations? Although my use would be limited, I am not going the HF route.
mtwaterguy
My friend just picked up his dog from the vet Yesterday. Had to have surgery from a piece of tennis ball being lodged in his stomach. $1500 later he's doing fine.
nine4gmc
Dallas
I see used ones on CL all the time, picked mine up from a garage sale. If you go the used route, BE SURE to test it for tracking. It will need a belt to test, ask if it has one before going to look at it. Plug it in and make sure the belt stays centered while running.
I picked up one a long time ago from a sale for $5 and since it was so cheap, I didn't even test it. When I got home, the tracking adjuster was completely broken...
KMScott
Belt sanders work very good but you have to be careful, being a little off canter can make a simple job into a nightmare. The choice of grits, and bumping a shoulder are also issues. Not everyone has a surface grinder in their basement. This old #3 Wilton had missmatched jaws and the anvil had some dings, my surface grinder made easy work of both issues. What grit do you guys use with your beltsanders? i am sure some would like to know, my guess would be 60grit.
Mark in Indiana
Southern Indiana
Good looking vise:thumbup: 60 or 80 grit will do fine.
I would also add that it is beneficial to use a light weight sander to reduce fatigue and they are easier to control.
mtesh73
Colts Neck, NJ
i clamp mine upside down in the center of the black and decker workbench. works like a bench mounted belt sander. i use 80 grit which gives a nice machined look to it. i use it on the anvil, jaw inserts and sides of the jaws.
recently completed C2 pictured for reference.
D
drivesitfar
MTesh: any chance you can show a few pictures of your modified belt sander and B&D workmate? did you see McB's Blockmeister that he mounts on his B&D workmate? sound like it works and nice job restoring your Wilton C2.
Montana: my daughter's dog has maybe chewed a 100 tennis balls but is was the only thing he would do to keep from putting the ball under my chair and trying to tip my chair over so i'd play with him. we have since used racketballs that he doesn't seem to like to eat. sorry to hear about your friend's dog.
Mark: nice looking friendly furry assistant and by the way we changed our's to a different diet and she is on the mend and hasn't thrown up for 3 days now.
Vert: I've heard that the belt sander works great to smooth out vises and anvils and I haven't used it yet because i like my vises to have their character marks. since the guys that make the some of the sweetest restorations on GJ said they use a belt sander i'd say that might be the best unless you have access to a mill. Fretters might say a hand file is best and i'm sure it has its merits too. I also agree with Nines that you can find many old nice sanders and maybe with new sandpaper for under $50 on Craigslist if you spend a little time searching for them.
Mark in Indiana
Southern Indiana
Vert: I've heard that the belt sander works great to smooth out vises and anvils and I haven't used it yet because i like my vises to have their character marks. since the guys that make the some of the sweetest restorations on GJ said they use a belt sander i'd say that might be the best unless you have access to a mill. Fretters might say a hand file is best and i'm sure it has its merits too. I also agree with Nines that you can find many old nice sanders and maybe with new sandpaper for under $50 on Craigslist if you spend a little time searching for them.[/QUOTE]
Hey Drives,
Glad to see that yours is on the mend.
I agree with you on leaving as much character as possible. However, I dug up an example of a vise that had too much character (before) and sanding down the jaw tops (after).
BTW: Of all the vises that I've restored in the past 5+ years, that is the only one that I had to use a belt sander on.
The belt sander is much easier to use than a mill for finishing a bare metal detail. But I wouldn't want to make jaw faces or a swivel base (future project) unless I had a mill.
mtesh73
Colts Neck, NJ
drives, here you go.
Fretters
South Yorkshire, England
Fretters might say a hand file is best....
IMHO, yup. :D I'm one of those who classes it as almost criminal to remove all imperfections. Factory condition exists when things leave factory. I'm not one for trying to reinstate that appearance with used kit. Removing burrs etc., (that's as much for comfort/safety as owt else. Some of those things can be really rough or sharp), I have no problem with, but smoothing a used surface to make it characterless; nope. Plus, files are far easier to control than belt sanders. You have feel as well as visual feedback with a file.
Lu-Max
Furry friends and vises you say?
Here is my old MinPin Maximus teaching my new C-2 how to sit.
Good boy Wilton, good boy!
97fordsuper
Gloucester, VA
This is Sugar Mama and my reed.
The base is cracked in several place and was previously brazed but it didn't hold up. My step dad suggested using a certain type of welding rod. Nickle rod, maybe? I cant remember exactly what he said. He also said we would have to preheat and slow cool down. I'm sure someone knows what welding rod he was talking about. Would that be a good fix compared to a good braze job? When it comes to welding, he's good.
