Demoman, I have one of those quick set Athols, pics here http://www.garagejournal.com/forum/showthread.php?p=3110446#post3110446
Unfortunately, as I posted a few days later, the swivel jaw is broken where the retaining collar holds it in the main body. I'm going to try to repair it someday, when I get a round tuit.
Jim
---------------------------------------------------------------------------------------------------------Any info on RAE vises. Says it a RAE 205 swival with 5" jaws and 12" open. Where these modeled after any other vise??
Brutus says "That was uncalled for!"
Well, it would appear that I was wrong...
OSU vs Oregon for all the marbles!!!
Should be a good one...
(A friend of mine wanted to play OSU instead of FSU...I told him he was wrong...)
Just picked up this little guy.... It's only 3" but turns smooth and you don't see too many on Craigslist around here so when you see one you race there before JasonJ gets there.
I have an extra tilt base for one of those, but I don't see the attachment holes in yours.
Demo.---There is an Athol #41 with the lift and slide capacity on page 413,----post 8260.
Yeah I notice that too? not sure why it doesn't have feet/tabs to lock it down so it doesn't move around on the drill press or bench... But it does fit perfect inside my 6inch Yost DP vise... A vise within a vise think about that? Mind blown right?... But figured I could use it to hold small stuff when I TIG weld... I would be scared with Mig I would get splatter on the main screw (even with a coating of some PAM spray)
It is an older style, you had to cut a notch out of the table to mount it. Later on the wedge piece disappeared and the base had a 90 lip in its place to keep it square.
Great, Thanks for solving that mystery![/URL][/IMG]![]()
Good advise from the master! Another option is to get a compliant material between the two. (Assuming the high spots aren't mountains...)
Since the mission is to not break off the mounting ears, you can look at other means to prevent this as well, such as using springs on the mounting bolts or limiting how far you tighten them.
When I mounted my Paramo #6, I didn't want to risk cracking its giant swivel base (Outlaw knows how big they are), so I fabricated metal sleeves with washer heads for each mounting ear. They could have simply been some bits of cutoff tubing and separate washers, but I made mine one-piece since I had a lathe. Then when I installed the vise to my maple top bench the sleeves limited how far the bolt heads could tighten down on the ears.
So here's a question....
Being largely a hand tools guy, has anyone had success removing the weld from a welded swivel jaw vise?
A Parker 386 and its issue attached.....
Thrumcap
Unfortunately (for you), some one did a pretty good job of welding that together. As outlaw said, it was a fix for a broken swivel jaw. see if you can hammer the retention pin out and look up from the inside of the casting. There is probably a piece broken off and to fix it they welded it solid. It could still be used as a standard vise, as long as it is square, but not quite as solid as a non swivel vise.
All: by the way i don't have the equipment or skill to weld yet so any recommendations on what to buy and how to learn??
