let's see your craftsman block grinders
McBrownie
Cleveland, OH
It looks like a sleeve to me, it's almost the same diameter as the inner race. Go ahead and cut off the inner race with a dremel and see what the other side of the "sleeve" looks like.
U, Drives and Ex,
Would you be worried about heat damaging the armature/rotor?
torqueman2002
SE Michigan
http://robrobinette.com/images/S2000/WheelBearing/BearingPuller.jpg
Is there any reason a bearing separator like this would'nt work?
Probably can rent one or borrow from autozone.
Once installed, if heat is necessary, it acts as a shield to keep heat away from other parts.
I use an OTC & Snap-On puller set up like that for Block grinder bearings.
It should work from what I can see, my caution would be to not heat the bushing to the point the bearing separator is damaged. Also, if you can keep the arbor/shaft cooler than the bushing with wet rags on both sides of the bushing, that should help removal. The idea being to keep the shaft cooler (smaller/contracted) relative to the bushing (hotter, larger/expanded).
Best of luck.
BTW - what is that out of?
drivesitfar
dodgejunkie
DJ, U, EX and McB: so the plan as best we can figure is to heat up the sleeve and pull it off then either pull off the busted bearing ring or cut it off with a dremel or another similar tool. do we agree on that as the best fix? then on the other side to heat up the sleeve and just pull off the old bearing. yes??
thanks guys and that makes sense to me.
I've found it easier to pull them both at the same time. It won't take as much heat as you'd think to get the sleeve, and inner race to move. I would not worry about the heat being an issue either. The normal operating temp of that armature is likely far in excess of what you'll impart to it.
Also, I have better success taking the outer race off(cutting it off) first. It generally pulls the damn thing apart, and you're right back at the inner race anyway.
If it is really stuck, you can take it down to the inner race as mentioned above, then support the race on something solid (RR track "anvil" for instance) and smack the race with a cold chisel (two man job to hold it, unless you fixture it...). it's hardened and with a couple of whacks will usually fracture and then it come off easy.
We used to take axle bearings off this way. faster and easier than pressing...
ichabod
minnesota
father bought it new, I remember the one it replaced. it look just like the one Bronson posted in the vintage grinder thread.
Kevski
Seattle
Thanks to all for the advice on this... got the bearings changed out, with some difficulty. Info in this post:
http://www.garagejournal.com/forum/showpost.php?p=4528613&postcount=546
drivesitfar
Kev: happy to hear your repair took a positive turn and i put more remarks on the vintage grinder thread you posted the link for. :thumbup:
DJ, U, EX, TM, McB, Outlaw and Gregthor: nice assists :thumbup::thumbup::thumbup::thumbup::thumbup:
twertsy
Reedville, VA
Pretty sure this is one. Never even had a clue that it was cool. I just grabbed it off my Dad's bench when they moved out. I'm sure it's somewhere in the 3,000 + pages of this thread, but where does one go to get the eye shields and shade for this? Also, were I to go about restoring it, where would I get the sticker on the front? And lastly, I noticed that when I work it a little harder than it probably should be worked, it doesn't like to shut off. It does, but stays at full power for about 3-5 seconds before winding down. Under normal/light workload it powers down immediately.
torqueman2002
SE Michigan
You can find some of the answers in the thread below in my sig. line.
".... stays at full power for about 3-5 seconds before winding down. Under normal/light workload it powers down immediately." Hmmm, no idea, new 1 on me.
Someone will pipe-in with an idea.
torqueman2002
SE Michigan
I'm not really in the market for one right now. :sad: I'm afraid if I added a brake to the BlockMeister, it would explode if I used it.
OK, OK. If it's still there when I head back to MI, I'll collect it up and save it for you (maybe, :evil:) for when you come to your senses.
torqueman2002
SE Michigan
DJ, U, EX, TM, McB, and Gregthor,
the grinder with the bearing sleeve issue we've been talking about is this Baldor so not exactly a throw away grinder as you can see from the link.
http://www.baldor.com/products/deta...Buffers&family=Grinders|vw_GrindBuff_Grinders
thanks for all the help and suggestions for the fix and the owner has seen them and he'll let me know if he has any success or more questions.
Thanks for the update.
It's amazing the variety of grinder configuration out there.
exmaxima1
Midwest
I'd guess the power switch is on its last leg. If the contacts are worn, they will heat up under load (high current) and possibly warp/deform the mechanism and delay the switching.
Does the switch get hot under load?
McBrownie
Cleveland, OH
Dirt/grime can do the same thing. An easy test would be to replace the switch with a new SPST toggle switch that you can pickup at Lowe's for $5. It's doesn't have to be the same style for the test. You could even use an old light switch if you wanted to. Or, just remove the switch altogether, tape the wires together, plug it into a switched outlet, and see if works the same way when you turn the power on and off. Sorry for the rambling, but I'm thinking as I type. ;)
vertguy
SE WI
Has anyone found a source for adding a flexible lamp to one of these grinders? My 6 inch has the knockout, so adding one seems to be easy. I found some sources for the flexible goosenecks, but not for the lamp end. Any ideas??
vertguy
SE WI
That's what I am going to want long term as the sewing machine light just won't looks right. I may grab one for now and keep an eye out for the "right" one.
pendragon1998
NE Georgia
Do I recall correctly that someone had located an original replacement shade from Sears? I have a gooseneck and I already picked up a solid brass lamp socket, but I need the clamp on metal shade and plastic shade.
Really, I would rather have a right angle style shade like this:
But I'd settle for the more recent style like this, if it was cheaper:
I'm just trying to do it on the cheap - have way too much into my restoration at this point - lol.
McBrownie
Cleveland, OH
What vintage? Flat top or round top?
vertguy
SE WI
Here's my grinder (397.19580).
McBrownie
Cleveland, OH
Vimco made the original right angle ones on the 1960's model, best I can tell. Mine ran $40, but was worth it to me because I wanted an original one. However, if you're not worried about originality, I also found these sewing machine lamps that are all over eBay for various prices while I was looking. Painted up, they should look and work nice as well.
http://www.ebay.com/itm/1-pcs-FLEXI...420&rk=2&rkt=6&mehot=pp&sd=161250386656&rt=nc
McBrownie
Cleveland, OH
Here is the correct style of your grinder. (This picture was reproduced without the express written consent of Bubinga. Thanks Bubinga!)
Finding one like that might be challenging. The problem with looking for anything older gets you into the "vintage industrial" market and the prices get right up there in a hurry. :eyecrazy: Are you looking to stay original or just get something that works?
vertguy
SE WI
Thanks for the photo. I am ****, so trying to find the right one would be my preference. For now, I can just pick up one of those sewing machine lights and repaint it. And just keep an eye out for an original.
While we are on the "staying original" topic, has anyone successfully color matched the silver paint on the shield frames? I assume that is same color as center area of the grinder.
McBrownie
Cleveland, OH
McBrownie
Cleveland, OH
Well, based on your comment above, I think your best bet on the paint is to get something close and paint both eye shields and the center tin. ;) And then you'll probably want to repaint the motor housings. And then the wheel guards. I speak from experience. :lol:
vertguy
SE WI
Good point. The grinder itself is too good of shape to touch, so I will need to get creative. While we have this going... my other "want" is a vintage/same era stand. I assume it will be like the lamp in trying to find along with not being cheap.
