BLUEPOINT counter-weighted crank bolt sockets
TOOLFREEQ
Cincinnati, OH
Anyone have experience with this type of socket? They are deep counter-weighted sockets to add more torque to break loose stubborn crank bolts, specificly for Honda and Toyota. The set includes 17mm 19mm 21mm. I dont see why the same principal would only apply to crank bolts so hopefully I get more use out of this set on other stubborn bolts. The set was $130
So far Ive used the 19mm on an 06 Honda civic crank bolt (with no pulley holder) and it came off easier than the lug nuts!! Which impressed me because some Honda crank bolts can really be a bear!!
Snapons web site is down right now for updates so sorry no pics or link
luvmyhondas
Cape Girardeau, MO
I saw them on the toll truck today. Almost pulled the trigger on the set, but wanted to do some research as to their effectiveness. I almost exclusively work on Honda/ACURA vehicles, so if they are legit I'm buying them.
zcamaross
They work. I'm a Snap-on dealer. Tried them out today on two engines. I was a tech previously and I was skeptical myself. But they really do the job. About to post a video of it on my YouTube channel zcamaross09
articsilber323
maryland
yes saw zcamarooss on this instagram today and looks like they work, would be good for people with weaker guns, i have never had problems with honda crank pulley bolts with my nitrocat 1200k.
Bigblue&Goldie
Care to explain how these work, the one picture I found makes them look like a standard socket with some more heft?
Skin
Boston
dpaton
Chicagoland, IL, USA
Anyone have an image? Can't find it on instagram and Snap-On of course has nothing for a non-catalog item. Trying to imagine how these work, but I can't.
2oolhound
BC Canada
After 1st reading this it sounded like they were just heavier sockets which would be like bolting on a heavier flywheel on an engine and I can't see the logic for breaking bolts loose with an impact. The term counterweighted however makes it sound like there is offset weighted sectors on the socket itself, maybe even mallory metal that creates it's own type of mini momentum between bursts from the gun. It will be interesting to find out how they work.
devoncoolman
quakertown pa
Not sure how exactly they work. There pretty hefty. Figure there might be a weight in it that spins causing inertia. Idk just a thought.
SYTNTYT
buddy had these and it grenaded after a couple uses. get the ingersol rand version. single socket and can be had online for around 60 bucks. Search google for Ingersol Powersocket- looks like a metal disc around a deep 19 socket. used a half charged milwaukee 1/2in gun to take off crank bolts all day.
2oolhound
BC Canada
Thanks and welcome to the forum SYTNTYT. Here is the IR link:
http://www.coptool.com/ingersoll-rand-to-add-50-impact-torque-with-powersockets/
It does look like a balanced flywheel type deal. I would have thought it would take just as much power to get it moving as it provided but maybe once it is in motion it provided some extra outward torque. It's interesting that your buddies' grenaded. It must be getting a rough ride. Too bad it's so bulky.
The snap-on one has the extra weight all along the length so it's less likely to explode.
I guess sockets were never considered as flywheels that provided torque but with this concept in mind there is room for some extra weight off axis to give the socket more torque before compromising power from the gun.
A guy should be able to heat shrink a heavy tube over a socket and tack it in place to get the effect.
Has anyone one noticed any performance differences between regular impact sockets and thin walled ones? (I never thought I'd ever be looking for thicker sockets) :headscrat
Scopes1980
I just purchased this 19 from snap-on. I tried 6 different impacts with a regular impact 19 and none would take off this Honda accord crank bolt. 1 hit with the counterweighted socket and it came right off
rancherbill
Foothills County, Alberta, Canada
rayh91
SoCal
Picked it up off the SO truck today. Just used it on an 08 Acura MDX with 63k miles. With a 2135qtimax on 160psi shop pressure. Took about 10 seconds but it took it off. Surprised the hell out of me.
This thing is stout and it cost me $45 off the truck.
Kracin
Omaha, NE
it's funny, i mentioned in another thread about how using impact sockets vs chrome sockets nets you more power and i got a lot of flack from it... maybe i can get a beer instead of the crazy eyes now :( :drink:
Skin
Boston
Im not entirely convinced. 2135 with 160PSI is a beast in its own right. I'd like to see a comparison on a torque tester which seems like no-brainer advertising material (if it works) for a product like this anyway.
ChrisLS8
I just have a 19mm that is welded to the inside of a 27mm socket if I remember correctly. Cost me about 10 bucks for 2 sockets and some time to weld it up.
Works like a charm.
rayh91
SoCal
I'd like to see one as well but there is no way a regular 19mm socket will break a Honda v6 crank pulley bolt loose. At least with my 2135. I've tried before. It's just a waste of time.
00S4Boy
Exploded the blue point one at my shop, waiting to check out the IR one to see if it looks beefier.
zkling
Any pics of the fragments? I'm curious, although expecting of the failure mode.
STANIMAL
chicago
Good to know these work . My SO dealer showed a set to me a while back , after doing another belt service , told him I am interested for the next one .
unslow1
Illinois
So how long until someone builds a 1/2 inch extension version? It would be nice to be able to use it on any socket.
colin39
Got a set yesterday to to a accord this morning. Belted the bolt straight out, i normally have to grab the 3/4 outta stores, big heavy orrible gun, but hey after a couple of quick buzzes with the facom awp050 she spun straight out. More than happy with £100 purchase
colin39
Buying lisle , here in the Y-uk, is like finding hens teeth. Lol , when i gave the snappy man the part number he looked at me like i had too heads. Hes been about 10years and has never sold or been asked for a set, he is how even showing them off i a honda dealership next week, and more to the point he is showing off my set gggrrrr, he is not a bad lad though.
