Paint OSB
bookman51
Kearney, Nebraska
Is there anything recommended to cover OSB that would smooth out the bumps? With the warmer weather I plan to start painting the inside of my shop.
Bookman
dps
Skim coat it with drywall mud. Fast, cheap, easy.
bookman51
Kearney, Nebraska
I did put drywall in most areas. I put up a few sheets of OSB where the wall might get bumped occasionally. Just trying to make the wall look similar.
Bookman
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Bookman
Your best bet is the drywall mud then. It is a bit of a PITA to get it to look just as smooth as drywall tho.
admactanium
It's not horribly hard. I had to do quite a bit of skim coating in my current house. Buy a bag of the fast-set drywall mud. I like the 90 minute stuff. Lay it all on with a fairly wide putty knife. Then when it's dried, first scrape off any high spots/runs with the same putty knife then use a palm sander with a dust collection system attached to a wet/dry vac. One more coat and quick sand should do it.
Although I'm confused, if the OP wanted to use OSB to make the wall a bit more durable than drywall, putting drywall mud on it will make it just as susceptible to bumps and scratches as drywall but with the extra effort. I don't think there's anything you can just spray or roll on that will give you a flat surface otherwise skim coating would be about 1/8 as hard.
