Repurposing old driver handles
BigJ73
wisconsin
This site is amazing! So much info. I am just a night n weekend warrior when it comes to wrenching on stuff. My family and I enjoy pulling garden tractor as a hobby.:3gears: here are some pictures of what I did after reading about it here. I have variety of tools and even have started to invest in to some snap-on stuff . Love the dead blow ball peen hammers, and the rachets.
maddawg1952
Peabody.Ma.
Took an old large flat bladed screwdriver handle, pulled the blade out ,drilled a 1/4" hole all the way thru the handle then inserted a piece of steel brake line that I had ground a nice 30 degree angle on the end, I use it for pushing thru a grommet or a firewall then inserting wires. learned that 1 from this forum as well lots of good smart folks in here.
T45
Those look nice OP, and welcome to Garagejournal.
Here are a few things I have made using unneeded screwdriver handles (or parts of them).
Nice! I'd really like a hand driver+chuck like that :thumbup:
how did ya'll secure it ?
John in OH
SE Ohio & Eastern Virginia
These are really nice!! Any more pics or details on how you are making all these different tools? How do you cut, drill, secure, etc.?
I'm gonna' have to stop throwing my old screwdrivers away!!
BigJ73
wisconsin
Those extensions look very cool. I was thinking about doing something like that just wasnt sure on the details.if anyone else has pics of stuff I would love to see them. I love looking at pics. My wife says I have a tool fetish. Possibly lol
toolmutt
Texas
Here's a couple of stubby spinners I made, 1/4" and 3/8" square drive. Also a couple of full size handle, stubby blade drivers.
BigJ73
wisconsin
All mine are just pressed together. For anything with a hex shaped or square shaped shaft I measure the diameter of the shaft (between the flats) and then use that as my drill size to drill out the handle. That way, when the shaft is pressed into the handle all the corners dig into the handle material and create a very tight fit that will hold securely.
The handles get clamped in place, and I drill them out using my drill press. I have found that cheap tile/glass/plastic paddle style drill bits work much better than regular HSS drill bits when drilling into clear handles. They are also very good at naturally self-centering when you are wanting to enlarge an existing handle hole. The self-centering feature is a definite lifesaver if you are trying to do all this with a hand drill, because you will have a much better chance of ending up with a straight hole.
For things like my little thumb bit holder and my short bit holder (that were originally round shafted) I just grind/notch lengthwise on the outside of the shaft so there is some "bite" for the screwdriver handle to grab. I make my notches by hand with a Dremel and a thin cutting wheel. You can visually see the final result by looking at my Williams rebrand ratcheting screwdriver shaft. Williams screwdrivers don't have any shaft finger knurling, so I made my own finger grip using the same technique.
I used the leftover screwdriver handle pieces to make the thumbwheels on my 1/4" socket extensions. I just drilled the screwdriver handle piece one or two drill sizes smaller than the extension shaft and then hammered it onto the extension. I do nothing to the extensions. The thumbwheels are only for quick finger loosening/tightening of bolts that spin too easily for a ratchet to function, so they don't need to be on there super tight. That being said I still can't make them budge using any force my bare hands can create. I have also made a few 3/8" drive extensions the same way, but I don't have any pictures of those at this time.
So, how do you guys get the old shafts out of the handles without destroying the handles??
I just heated up the shank a little until the plastic let go of it,allowing shank to slide out
BigJ73
wisconsin
Here are 2 more things I made today. I think I'm obsessed. Lol (3/8" ex driver ,and 1/4" stubby )
PCO6
Newmarket, Ontario
I made these out of old screw driver handles and a couple of feet (each) of steel brake line. I use them for threading electrical wire through hard to reach spots like up under a dash board. I thread the wire through the open end of the tool and push it through to where I want it.
View media item 47893
EDIT: I just read post #2 of this thread. Same basic idea. :thumbup:
mkv221
Ontario Canada
Mastercraft 1/4" ratchet with craftsman handle. Machined down the ratchet to fit the handle.
