AnonymousToolGuy
- Joined
- Jan 2, 2015
- Messages
- 75
Background on Koken stuff if you want the long version: http://www.garagejournal.com/forum/showthread.php?t=212739
Short version: japanese made sockets and socket accessories
Back Story:
I figured I'd break out into a separate thread to make anyone searching for a direct comparison have an easier task.
My toolbox mainly has usa-made CM sockets currently. However, I wanted sockets that would fit a bit more snug over bolts and not have so much play that I'm damaging/gouging fastener heads. I don't turn wrenches for a living, just work on my own car and other stuff around the house. So I came to a crossroads: Koken or Snap On with a student discount. In either case I won't have any warranty support, so that's something to keep in mind, but I've never broken a tool that was used properly (and I always try to use the proper tool for a job). Both are priced roughly the same (SO is probably a bit more expensive).
So on to the comparison.
The fasteners:
Brand new 17mm drain bolt that I had on my workbench. I also selected a couple 10mm power steering pump hose bolt, 12mm intake manifold nut, and 14mm strut mounting nut. All of these bolts are in good condition and not excessively dirty or rusted.
The sockets:
-Snap-On Semi-Deep Metric
-Koken Z-eal Deep Metric
(Z-eal is Koken's low profile and tight tolerance line of sockets, their regular line may be worse)
-Craftsman sockets deep. USA made. ~3 years old.
The results:
First off, my SO sockets came coated with oil. I don't know if this is laziness on the part of their manufacturing or anti-rusting, but I would hope chrome sockets aren't rusting on the shelves without being coated with oil.
The order of testing in all the videos is Craftsman -> Koken -> Snap-On. I tried to face the stampings on the sockets towards the camera so you can see movement. All videos are in 1080p, so you should probably watch them in that resolution instead of the default 360p.
10mm bolt head - Koken won. I found a 10mm bolt that was very snug fitting for both the SO and the Koken, and it had nearly 0 play with the Koken socket. There's was just a hair's play with SO, so it's a close second. Craftsman had the most play.
12mm bolt head - Koken won. Almost no play. SO and CM were about even.
14mm bolt head - Koken won, but not by a huge margin. All 3 had similar play.
17mm bolt head - Koken won...clearly. Because this was a loose fastener I was able to mark how much play there was (turn bolt to the right, mark it, turn to the left, mark it). The SO socket had more play than the CM socket! (*this is a newer laser engraved made in USA CM socket). Koken socket had barely markable play.
Conclusion:
Cutting straight to the point - Koken Z-eal won over Snap-On in this informal test on a few nuts and bolts. Snap-On comes in second place. CM comes in third. I'd like to test how well Koken's regular non-Z-eal sockets do. I will say that aside from the oil coating, the SO sockets are the nicest looking. Polished to a mirror finish, and the reliefs in the socket end for fastener corners are well defined semi-circles. The Koken sockets look like they get left with a slightly rougher finish and coated with hard chrome.
Back Story:
The fasteners:
The sockets:
The results:
- Video: Link
- Video: Link
- Video: Link
Conclusion:
