vegar
Great use of that garage.
nice job hanging those clamps and tools on your wall. in case you have other types of things like that you might consider making a rack on the back of your man door.
looking good so far
Excellent work, Kudos!
Im also diggin the ample electrical service, not sure if you said it but how many amps do you have going to the place?
The colour is a custom match we use where I work, I can pull the colour code if anyone is that interested. The paint is sherwin-Williams urethane alkyd enamel over a SW Corothane MIO-Aluminum primer. Both are industrial products.Ainsley: awesome color. care to share what color and brand of paint that is? great work on that old lathe.
i hope you are able to get that dust collection and tool set up you had at your last shop because i'm sure i could use something like that in my shop. is it powered with a small shop vac or are you getting a bigger system for this garage?
I got my kit from lee valley: http://www.leevalley.com/en/Wood/page.aspx?p=62594&cat=1,42401,62597And where does one find clear tube and fittings like this, very well done, IMHO.
Nice work, very good organization!
Excellent use of space.
Love your shop. Everything has turned out great. Nice tools and set up. I like your projects a lot!!
Awesome vent setup.
What blowers did you use and with what results?
I'd love one that would push or pull depending on the need.
Thanks, I don't have any pictures of the frame. I made it myself out of 1" angle and a bit of 1" flat bar. I figure I could have up to 200+ lbs in the rack and I doubt the ply back panel would support it without some sagging. I actually made the frame too tight and ended up having to beat the plywood box into it with a dead blow mallet... not sure if I will ever get it out now.Ainsley: nice frame and storage for small parts, nuts and bolts you made. do you have any pictures of the frame before you put the plywood box in it and did you make it or buy it and where or how?
The totes have mostly shop supplies. Some of the stuff is for household renovations ie. electrical boxes, plumbing parts; but most of my renovations materials is on a large shelving unit in the basement.BTW i do like your hanging shelves and how well you have everything organized. is that household type stuff in those blue boxes or supplies for the shop?
not sure if you need a big work surface, but having one on wheels sitting in the middle of the shop is kinda handy even if you just set stuff on it. also when it's nice out you can roll it outside and work out there or have more room in your shop.
Love your shop. Can't wait to see it when your are completely done. Your wiring and control boxes are aspiring. I love the setup you have on you air cleaner. I need to setup a timer on mine. I forget and leave it on have the time. Look forward to your updates.
Nice woodworking setup!
Ainsley: shop is really coming together for you. thanks for sharing pictures of your new ducting. is that vacuum system you have a Grizzly or do tell what brand that is? i'm also a little curious how you are going to use the tubes on the Drill Press and Bandsaw or is it more just pulling the hose over after the work is done to clean up instead of during the drilling and cutting?
Thats a lot of work in a small space nice job! That vac ducting is a really good idea!
The wall clamps are uni-strut with 2" pipe clamps. The kit comes with plastic two hole clamps to go flat on the wall but I prefer the flexability of the uni-strut. I will be running air lines over the vac lines along the uni-strut as well.did the wall connections come with the kit for the duct work or are they your own design? they look like short pieces of unistrut with some pipe clamping device.
Yes, all the clear 2.5" lines are connected to the shop vac. The bucket has a pre-separator on top called the Oneida dust deputy. It removes most of the dust etc. before it hits the shop vac so the filter lasts longer and the suction doesn't drop as quickly. The kit I purchased comes with plastic blast gates which work well but they can get jammed with grit, preventing them from closing completely. If I could do it again I would have started with these gates even though they are 3x the price. I have a few of the 2" and quite a few 4" and they are VERY nice.so does that side of the garage go into the shop vac? it also looks like it goes into a small 5 gallon bucket? sorry for all the questions, but as you know i like that design so I (we) want to know as much as possible. BTW does it work as well as it looks to keep dust and **** out of the shop?
