Looking to buy a nutsert/rivnut tool
stutts
looking for some sugestions, in a quality long lasting tool, needing it mainly for nutserts at the moment, but will be riveting also down the line.
thanks guys
CobraRed
I use Astro's 1442 and it's treated me well, saw their 1442 at SEMA had a new head piece that is like a quick change that doesnt require tools to change out the mandrel/nose piece.
383 240z
Findley Twp. Allegheny Co.
I have a Blue Point one, had it for years, pulled a ton on nutserts with it when I was building custom cars. It will pull up to 1/4" with the arbors that I have, think I have down to #12 IIRC. I don't know of any nutsert tools that also pull rivets, but I could be wrong.
I'm pretty sure its a re-branded Marson Keith
rshadd
Doylestown, PA
I have the Marson 39302 Poly Nut Thread Setter Kit. I don't use it often, but when I do it always works great. It's built to last. The larger nutserts do require a good amount of hand strength. If you plan on setting a lot of these, you might want to consider a hydraulic or pneumatic gun.
This is a 1/4"-20 nutsert sample...
stutts
probably have a total of like 20-30 to do max, going with m6-m8 size serts, are those hand ones capable of doing those?
thanks
i will be better at searching from now on.
miketyler
Cedar Hill, TX
Nothing ***** more than removing a screw later and having the nutsert spin in the hole. I might also suggest you consider the rivnuts with the serrated flange so they bite into the material when pulled.
Aircraft rivnuts require that you notch the hole to accomodatte locking tang on the flange. I have had better luck with the serrated type. I actually add a little structural epoxy on them to give them a little more holding strength.
n8n
Curtis Bay, MD
If you only have a few to do you don't need a tool at all, you can fake it with a long machine screw and nut and a few lubed washers...
Sent from my XT897 using Tapatalk
xxaler
Sutton Ontario
I hate to be the **** that always recommends the cheap brand, but...
I'm using the Powerfist (Princess Auto) nutsert gun and have probably put somewhere around 150- 1/4" nutserts and 200+ 10-24 nutserts through it without any problem. Great tool to have, I was amazed I went wandering through my entire life lost and confused before I found this tool.
cheechi
Triad, NC
I can tell you something that ***** more. When those bite too much or the wrong way and basically you have reamers because they didn't set right. Drilled out plenty of that type and I don't like them at all. The best are the square, notched, or hex style but you have to have $$$ for that kind of setup.
I do like your idea of epoxy though I have used that from time to time.
My only experience with actual sert guns is Bollhoff pneumatic or air over hydraulic I forget which. I wouldn't know where to buy a hand one other than Amazon before these recent threads.
Loudpipes66
Southwest PA
Check ebay. I picked up a Blue Point HP400 complete with all the dies and a ton of nuts in excellent condition for $56 shipped.
LXCam
I have both the Marson and my original I bought 35 years ago like what magzilla posted. I use the marson all the time and echo going with the sheraded inserts. But my old one is my favorite, it seems to do a much better job locking them in, it's just not as fast.
cruzer75
If you dont have a lot to do the manually ones with a bolt, washers and wrenches works ok. We sell kits at work for customer install of 5mm bolts and they work fine, no complaints.
lashlee
I second (or third) a Marson. At one point I misplaced my 1/4-20 arbor and bought a HF one and broke it on the first try. Horrible design and cheap materials. Get a quality one that will last.
Cope
Houston, TX
thanks
M8 you will need Aluminum inserts. I did a couple of steel ones with mine but had to use a c-clamp to tighten it.
LXCam
Anybody else get a kick out of the name "Nutsert"? [emoji12]
:p Heck I have a mini socket set called the palmster....had to have that one. :evil:
Here's both sets. Like I said earlier, the old unit makes for a more secure crimp and it goes up to 3/8". One of these days I gotta remember to order more of those inserts.
jrrazo29
Kind of expensive, but at work we have a Blue Pneumatic rivnut tool. Takes literally 3 seconds to install a rivnut.
wagzilla
Arizona
hi guys Kimball Midwest is the company
#5/16-18 Tric-Nut Insert Conversion Kit
For Use With Tric-Nut Insert Installation Tool 85-051
Package Quantity: 1
you don't need a special tool to use it
James
K-Dog
Millersville Maryland
Package Quantity: 1
James
Lowes? Home Depo ?
I looked on Amazon and unless I was using poor search terminology ( which is likely ) I cant find that tool.
Ramper
Southern MN
Is there a conversion that allows you to use a pneumatic riveter as a nutsert installer? The pulling is the same. I would LOVE a pneumatic, but can't justify the cost since I already have a good air riveter.
garandman
Boston MA / Mt Sunapee NH
Been using the 13” Astro Pneumatics 1442 to install McMaster heavy wall 1/4” Nutserts. It has the quick change head and came with mandrels up to 5/16.
Wouldn’t want anything smaller.
The Tool Tyrant
Bonita, Ca. (San Diego)
https://www.fsirivet.com/6bFQM3N9IqgAHoP/1344377857D100MIL1_D180.pdf
We have a few of these in the shop and use them everyday. Hydraulic is much easier to use than the less expensive manual :Mr.T:types...especially if you have a lot of Rivnuts (nutserts) to install. We use the serrated style Rivnuts (nutserts) and NEVER have issues with them spinning :willy_nil. I would venture to guess that we have installed at least 10,000 Rivnuts (nutserts) over the past ten years, so I'm not blowing smoke here.
You can still find a good deal on these on ebay every now and then if you keep your eyes open :yikes:
