8mm Flare-Nut Wrench?
Ign
Butte Peak ND
Absolutely but as 5/16" and 8mm are within the thickness of a human hair I doubt the castings are any different.
Jason280
Yep, you can usually just substitute a 5/16" wrench. I have to use one to remove the bolt holding the carrier pin in place in a Ford 8.8 rearend, usually use the box end on a Kobalt wrench.
Fedwrench
Valley of the sun
PROTO J3707M gets you a 7 X 8 mm flare wrench.
MAC, Snap on, and Matco have 8mm combination flare wrenches.
Probably the most useful Flare wrench I own is MAC's 8 X 10 mm Flare wrench FB6810MMR.
Never seen a 6mm flare wrench. That small a 6 mm socket and get messy would work best I guess. :beer:
rodster_67
Near Allentown PA
Jason,
Would you remove that distracting avatar, I can't concentrate. :D
Monte
Germany
Stahlwille open ring 24 (#41080810 (8 x 10 mm))
Hazet 612-8X10
Hazet 612N-8X9
Gedore 400 8x10
Elora 121-8x10
John in OH
SE Ohio & Eastern Virginia
If you don't want to spend much, Sunex makes an inexpensive 8x9 flare nut wrench:
Sunex Tools Flare Nut Wrench
Flare Nut Wrench, Steel, Polished, 8mm, 9mm
Part Number: SXT-980905
On-line from Summit Racing for $2.97. Obviously, NOT made in USA.
