Onefastgsx
Well basically I am making (copying) a throttle body adapter to run a larger throttle body on my car. I have made a few before with great success but this time there is something a little different. There is an area where air can flow through and around the butterfly valve for the car to idle smooth. This is accomplished by notching a section in the adapter right above the main port.
Here is the notch I'm referring to in the original adapter:
Here is the chunk of aluminum scrap I am cutting my adapter out of (seen on left) next to the original I am copying (on right)
Everything I have done on mine up to this point has been done with a drill press. I do not own nor do I have access to a mill, which is what I'm sure is used to typically make a notch like this. Everything I've read online says it's a serious safety issue to try and put pressure on a drill press from the side unless some modifications are made to it (different bearings, support for the chuck and neck and so on)
I'm not looking to spend alot of time modifying my press to make it into something similar to a mill. But I do need a way to make this groove in the plate I am making.
Is the any hand/power tool that I could use to make a notch like this? It doesn't have to be perfect, but the cleaner and smoother the better.
Thanks for any tips or advise.
Craig
Craig
