fans for a 40x60x12 shop
conceptmachine
Fellas,
I'd like to get some air circulation for my new build shop. Should I get industrial ceiling flat mount fans (like in houses) or should I get angle mount fans that mount to the ceiling and come in at an angle? How many and what size would do? I'm just looking to move warm air and to help keep condensation down at the times I need it. I have a large drum floor fan.
thanks for your input,
Jim
rburke65
Canfield, Ohio
Concept, not sure I understand. Industrial fans like used in houses? Fans that mount to the ceiling and 'come in at an angle"?? How many do you need? I would think the number would be personal or based on the amount of CFM output of the fan. Good luck.
C
conceptmachine
Rburke, industrial type ceiling fans, that look like typical house ceiling fans, they just have an industrial motor. I've been doing research and I think I'm just going to go with two wall mounts that have 3 speeds. I'll mount them at opposite ends of the shop near each corner. CFM on high is around 8000 a piece. That aught to be plenty. If i need more circulation I will use my existing ground unit.
rburke65
Canfield, Ohio
I think you will be fine with the two fans, you won't need a wind storm, just air movement. I have yet to wire in a fan....32x56x13..... but I'll get there.
724tim
MT.Pleasant PA
Low N Slow
I have 3 of these in my 30x50x10 garage they move a lot of air.
Industrial 60 in. Indoor Black Energy Star Ceiling Fan.
The industrial Hampton Bay Black Energy Star Ceiling Fan features a powerful 188 mm x 18 mm motor and 3 plastic blades that provide up to 9,630 CFM airflow for highly efficient air movement in indoor industrial environments.
http://www.homedepot.com/p/Hampton-Bay-Industrial-60-in-Indoor-Black-Energy-Star-Ceiling-Fan-26629/202670138?N=5yc1vZbvlqZ1z13nwj
I have 2 of these in a 36x48x14 and they move plenty of air. I mounted them in the peak with 4' downrods.
bookman51
Kearney, Nebraska
I have four celing fans in the 40 x 40 shop part of my building and they do just fine. A frined of mind has angled fans in his, which a bigger buiding (maybe his shop part is 50 x 50), and he has them on a thermostat set to go on at 70 degrees He likes them real well.
I suppose I could put mine a thermostat, but I have them variable control. In the area I am working this winter, I turn the two to fairly slow and on the other side of the shop I set them fairly fast to push the hot air down from the roof. I have 15 foot sidewalls and no celing, but an insulated roof. I got my fans and controls through Farm Tek. Had them up a couple of years.
Charles (in GA)
50 mi south of Atlanta
Short thread on shop ceiling fans.
http://www.garagejournal.com/forum/showthread.php?t=5186
Longer thread.........
http://www.garagejournal.com/forum/showthread.php?t=11627
Thread on fan controls.............
http://www.garagejournal.com/forum/showthread.php?t=180484
My Home Depot Industrial ceiling fans on homemade 4 ft downrods.
rburke65
Canfield, Ohio
On the Home Depot 60" fans....4 speeds ..... With reverse function......where is the "reverse function? On the fan itself and not on the wall....or? Thanks.
Low N Slow
The reverse switch is on the fan behind a cover on the back of the motor.
rburke65
Canfield, Ohio
Thanks Low. Can't see getting out the ladder to reverse the fan. Might need another switch and an extra setoff wires.
stage20
pcola FL
how noisy are these home depot industrial fans compared to a direct drive drum fan or a 30" pedestal fan? im leaning towards pedastal fans or wall mount, but i know a couple of them going can make some noise since they are direct drive.
aka Larry
Eastern, NC
On mine (I have 3 in my shop, see link in my sig below) all you hear is the rush of the air, not the motor itself. Pretty quiet IMO.
