Delta Paint Color
jsharpphoto
Dallas, TX
Has anyone found an off-the shelf color that's a good match for the blue-gray color Delta uses on their stuff? I have a mid 90's drill press and bench sander that both could use a refresher. But neither of them have a surface that is large enough, flat enough or clean enough to get a scan.
gilbo
hope this helps
DELTA PAINT COLOR
for my delta dp & craftsman grinder resto i went with rustoleum dark machine gray
u can look below in my sig for pics on both
J
jsharpphoto
Dallas, TX
Thanks. I will swing by sherwin williams and check out the high seas color. I would have just gone with my "garage gray" which is rustoleum anodized bronze, but I just painted the bench that color.
ar2stp48
Magnolia, Arkansas
Please post your findings on the S/W High Seas Gray. I went to two stores last week looking for it; was told at one store it had been discontinued
Have several spray cans of possible matches and nothing yet. Currently restoring a 10" contractors saw; waiting is a wood lathe. Would like to find something better than Gray; used it on the bandsaw, but it is missing the blue tint delta had
454ragtop
Carver, MA
No. it's a brand like Krylon or Rustoleum. The local Carquest store here sells it, bet it can be found online also. I actually painted a Delta drill press with it and blended to the original paint under the belt cover, can't tell where one starts and other ends.
Jim
Stuart in MN
Minneapolis
I've used Plasti-kote spray paint before and it's good stuff - the cans work very well, you can get a nice finish with it.
FJ 432
Littleton Colorado
You can mix Rustoleum's smoke gray with a blue that they also sell (the name escapes me but it's a medium blue) and it gives you a bluish gray. Tint to your own desire. Doesn't help if you want to spray can.
The Cobbler
hope this helps
DELTA PAINT COLOR
I had a can of this mixed up , and it is too dark. way darker than newer machines. maybe it's an old colour, not sure if it was mixers error, or the formulas have changed or what. I wasn't present when the mix was done, nor did they have a sample to compare it to. The kind friend that did it for me simply gave the store the formula.
