robertwhite
- Joined
- Feb 10, 2010
- Messages
- 433
So in my barn I have two separate home runs (12/2 w/ground) for water tank heaters (cows). Been using the setup for several winters.
20 amp breakers, heaters pull about 17amp each, separate GFCI at the tank end up about 8-9 foot from ground.
Usually, I only run 1 heater to save power unless I know it will be way below freezing. I just step up on the tank and push the GFCI button to kill the circuit instead of going to the panel, hitting the breaker, etc.
Simple enough, right?
So............ I go to reset the GFCI and it will not click, try a couple times, nothing. Go to panel side and play with breaker, retry GFCI, nothing. Pull GFCI off, put a ringer on power side of wires, ringer goes off, so I have power.
Change out GFCI, retry, nothing. Does exactly the same thing old one did.
Change out breaker, GFCI still won't click on. The little orange light on GFCI is lit, and if I push the button and hold it in, the light goes out, telling me power is there.
WTF?
* I have not tried either GFCI on another wire, but the 2nd one was brand new, so odds are it is good)
WTF?
