furnace cycles every 7 minutes
jkmech
I have a frigidare G6RA 80 percent furnace and I just noticed the furnace cycles constantly when it reaches the selected temp on thermostat. it will stay on for a long as it takes if you select a higher temp on the thermostat for as long as 30-40 mins to reach that temp with no stoppage everything normal. but once it reaches the selected temp it will cycle every 6 -8 mins. on, then shut down normally with burners shutting down and fan cooling furnace down for about 120 seconds then about 5-8 mins latter it will start up normally again run for 6-8 mins and shut down normally again and continue to do this all night long. I changed thermostat and put a new control board in furnace also cleaned burner temp probe and checked overtemp switches . I don't think this is normal or maybe it is. any ideas I would like any suggestions thanks
Advan
Ontario, Canada
Every mechanical thermostat I've seen (which isn't many!) has a cycle time adjustment, usually behind the cover. I'm sure electronic ones have the same, built in to some hard-to-find menu!
J
jkmech
thermostat is Honeywell RTH6350D1000 PROGAMMABLE 5-2 DAY MODEL I see no adjustments any ideas
Triple macs
Honeywell calls it Smart Response Technology. They claim it is accurate to less than one degree. I have a Honeywell 6000 tstat with Adaptive Intelligent Recovery. I have it programmed to heat to 70 deg at 6:00 a.m. Since the software "learns" by tracking the time it takes to satisfy that temp, my furnace typically comes on at 5:35, so at 6:00 it is already at 70 degrees. Like yours, mine will short cycle numerous times per hour to maintain the programmed temp. Fortunately, it does not do this in cooling mode. Otherwise the short cycling would beat your compressor to death in no time. If yours is like mine, in the setup menu you can disable the "smart" function so it will run like a conventional tstat.
Kev442
Wi
All electronic thermostats ship with a max of 5 or 6 cycles per hour. Whether you can change that, IDK.
Be happy that it actually shuts off 6 times in an hour. When it is -15 and windy up here, the furnace will run for 15 minutes, shut off, then start up again and run for 15 minutes!
fastcar1954
was there a switch inside the tstat for using gas or electric furnace? maybe set to electric furnace mode.
metaldad
nw indiana
it cold outside, gonna get real cold when that sun goes to sleep.
now is not the time to phuck with a heating appliance.
could be normal operation. like i tapped, it's cold outside.
does it overshoot temp? no? leave it.
bonneyman
Desert SW
That sounds a bit fast, but could be current conditions causing it. Normally a furnace will cycle 2 to 3 times per hour. That's about 12 minutes on, and about 12 minutes off.
Most electronic t-stats have automatic have a way to adjust the cycling rate. Pull out the owners manual, and go to the advanced programming section. You should find the correct screen in there.
If thermostat is new, could be a hole in the wall behind the thermostat is letting cold air come in the back, throwing off the temp sensor and making it cycle funny. Have seen that happen.
BryanB
WI
I just got rid of my honeywell and bought a lux. Cant set a temp swing on the honeywell. You can on the lux. I had the same issue as u and hated it!
boomerangg22
I too just got rid of my honeywell 8000 bought a Hunter. cycling would drive me crazy. kept telling my wife furnace is old and it's gonna go out if that keeps up. seems to not do it with the hunter s much yes still does but only couple cycles at a time
Buster21
Idaho
I had a gas furnace and replaced the old mercury round dial switch thermostat with a new electronic thermostat. Then mine started doing the same thing as yours, the new thermostat tried keeping the temperature at the exact setting. I ended up replacing it with a "new" old fashioned dial type mercury switch witch has a much wider temperature gap.
Canoe50
Rochester, NY
Canoe50
Rochester, NY
In case you didn't notice, there is a dedicated Heating & AC forum on this site.
Click on ...The Forum... to bring up all the different categories.
Thought it was worth mentioning since you're new & might have missed it.
