I have a frigidare G6RA 80 percent furnace and I just noticed the furnace cycles constantly when it reaches the selected temp on thermostat. it will stay on for a long as it takes if you select a higher temp on the thermostat for as long as 30-40 mins to reach that temp with no stoppage everything normal. but once it reaches the selected temp it will cycle every 6 -8 mins. on, then shut down normally with burners shutting down and fan cooling furnace down for about 120 seconds then about 5-8 mins latter it will start up normally again run for 6-8 mins and shut down normally again and continue to do this all night long. I changed thermostat and put a new control board in furnace also cleaned burner temp probe and checked overtemp switches . I don't think this is normal or maybe it is. any ideas I would like any suggestions thanks
