Radiant heat 101. Let's hear the details
skipnay
PA
I mean come on its a tube in the concrete. Ok so what does it take besides that? Do you have to insulate between the concrete and the stone? What does it cost in material to do say 1,000 square feeet so it's easier to calculate if people have less or more space. What do you have to do to maintain it? Does the concrete have to be deeper? Do you have to keep it away from walls? Also how do you keep from hitting it later if you drill holes in the concrete?
Bondo
Greenfield, Maine
Ayuh,.... Ya crank up the heat, 'n use an inferred thermometer to See where the tubin' is,... ;)
JCByrd24
Bath, ME
Absolutely insulate between the slab and the ground below, 2" foam minimum. No foil/bubblewrap products. Also insulate the edges of the slab/frost wall/stem wall. You don't want a path between your heated slab and anything you don't want to heat without insulation in between.
kj_mustang
Harrisonburg, VA
fittings, pumps, controls, manifolds, heating source, pressure tank, drains, cut offs, air eliminator, etc.
Yes, if you don't want to waste money heating the ground and you need a vapor barrier under the foam insulation.
less than $2,000 for 1 pump and all the other stuff except the heating source. Half of that cost is 2" foam insulation. Heating source will vary greatly in price with type.
Perform required maintenance on heating source and maintain water and pressure levels.
No
Pex should be spaced 12" away from exterior wall and the first two runs of pex closest to the wall should be spaced 6" apart. All the other pex runs would most likely be spaced 12" apart but heating design requirements will determine that.
Do accurate measurements on the layout and keep photographs and all layout drawings. You have to design the layout with walls, lifts, etc. all taken into consideration.
theoldwizard1
SE MI
Vapor barrier.
Some foam boards will provide adequate vapor barrier if you use 2 layers on 1", making sure no seams are on top of each other AND use the proper sealing tape.
theoldwizard1
SE MI
This might sound complicated, but for an experience installer it is nothing.
Neatness counts ! Check the installer's other customer to see if they are happy.
