most useless tool
pipehack
chicago
That is the coolest thing Ive seen all day!! BTW noticed your in my neck of the woods :)
Sean
Mine too. Or close enough. I have a buddy that lives out there. I call It Carol's golden Stream. Something to chuckle about.
TAMPAGT07
Palm Harbor, Fl
Usually when I need a tool, I go and buy it and use it. If it is a piece of junk, it goes right back, usually to Harbor frieght.
Jononon
Cordless drill that died after 10 charges.
Cordless drill that made my hand bleed putting in decking screws.
Cordless drill/driver that has a cap containing bits, which are impossible to remove without using a pair of pliers.
You may be detecting a pattern...
mkdive
NPB (Socal)
That caliper is impressive. Not sure what the hell I would ever use it for...but very cool non the least!
Dremel tools are great IMO. I use mine all the time for lots of different things.
eric87
Dremel. I can find any use for it that makes it worthwhile, it either can't do the job or doesn't do it well.
i used a dremel to knotch glue trowels, wire brush rust from tight places, polish parts.sharpen chain saw and lawnmower.i think it is a great tool
swgray
maryland
This caliper, 7 feet long!!!...although it was the most useless (because it needed three people to use it...LOL) it was also the coolest!!! I also got the Granite surface plate it is sitting on.
I occasionally use a 40" caliper at work. It can be a handful. Its easier to use laying flat on a table. What is it you're measuring with it?
Moose-LandTran
The Brink of Insanity (England)
I believe 16mm is the correct hex size for an M7 or M8 thread, as according to DIN (German) standards. You'll find German cars, especially VWs and Audis, are riddled with them, my 16mm and 18mm sockets are used a lot.
Mr.Nutcase
USA
My worst would be:
Dulalast ratchet I bought a Autozone!, it should be called Duracrap..
Old Donn
Does tools you've never used count? If so, the cold soldering iron. Got 2, never used either. Most useless I have actually used? That's easy, the Gator-Grip socket.
Rickster
SE PA
I got a Performance disc brake piston collapser in a box from somewhere. I just had a chance to use it on my Ranger. Cranked it down and then the knob kept turning but everything else stayed still. I tossed it in the trash and went and got one of my huge old C-clamps which did the job just fine.
stioc
SoCal
Wagner paint sprayer. Tried once. Directly into the dumpster.
Dang, I was planning on buying one since I have a big paint project coming up. Although I did notice the handheld ones have bad reviews but their "paint crew" model has good reviews on Amazon but for $200 I'm reluctant to try my luck :lol_hitti
stioc
SoCal
I just used 16mm on my Dakota installing a class III trailer hitch. I'm sure it needed a 5/8" but my 201pc socket set from craftsman didn't have a 5/8" 6pt socket...or maybe it had one and after 5 years I lost it.
DashEight
C-man powdercoating gun. Just skip on this peice of junk even if it's free. Eastwoods Hot Coat has been far more reliable.
rsanter
visalia ca
I had one of the cheapie wagners that you pour the paint into it cup that attaches to the bottom of the unit.
that thing worked great....for about 10 min and then it would never do more than spit and splatter the paint
a friend has one of the paint crews and it has worked well. I was happy with it when I borrowed it
bob
fotoflojoe
Boston, Ma/South Shore
Gotta say that I agree with this - mostly...
At an old job of mine, they had a Dremel in the tool crib, I used it all the time for various tasks. Man, that thing kicked ***.
Fast forward to last year, I needed to wire brush some small pieces, so I picked a Dremel kit of my very own. Started out fine, but six months later, the thing just doesn't seem to have the oomph that it first did - it spins slower and bogs down real easy.
fireguy
I bought a battery operated Dremel. The battery would not hold a charge long enough to cut off a sprinkler escutcheon. It did have a nice bag though.
ImportTuner
The brushes are probably worn; had the same issue, replaced the brushes and ran like new .. :)
nate379
Palmer, AK
I bought a set with the drill, skil saw, sawzall and light when they first came out around 8-9 years ago and I still use them all the time. I am on my 2nd set of batteries though, but not bad considering how often I use them. I hardly ever pull out the corded versions.
I have a $400 18v Dewalt drill and I rarely use that one cause it weighs 5 tons and kills my wrist after a while. Only reason I keep it is that it's a hammer drill.
-sears 19.2V drill/cordless screwdriver set with 2 batterys and 1hr charger, POFS. not real tons of power for 19v and on top of that, both batterys died with in a few years of moderate/light use..junk, 75 dollars later..
kooldino
South Jersey
This is easily the worst tool I ever bought:
It was a Crescent adjustable socket wrench. It looked like a super-cool wrench that I could keep in the trunk of my car for emergencies.
After purchasing this steaming pile of vomit, I tried to remove a not-particularly tight bolt. It did a spectacular job of rounding off the bolt head. Into the garbage it went along with my opinion of Crescent.
nate379
Palmer, AK
I have to strongly disagree on that! Good solid engines that have been around for a long time!
I'm not aware of any brass mallets they make, you must be confused with something else?
Anything from Cummins (except the solid brass mallets)!!
I have to disagree with you there. That packer (from OEM, if I recall correctly) is one of my absolute favorite timesavers when used with a pneumatic grease gun.
nate379
Palmer, AK
A tool that is ******* me off is the new florescent shop light I got from Sears.
I had the same version before. Had it for a good 6-7 years and between running it over and dropping it a million times it was getting worn out. The cord had bare wiring in a couple spots that I had fixed with black tape.
I get this new one as a gift for Christmast last year. Looks to be the same and even has a plug in it too! Cool right? HELL NO!
The cord is super thick and stiff and is only like 6 ft long. It's bad enough that it unplugs out of the wall if you try to straighten the cord! My other one had a 15 or 20 foot long cord that was flexible like a normal cord.
Thinking about giving it away and buying something else. I'd return it but I just pulled it out of the package a few weeks ago (was waiting for my old one to finally kick the bucket), so it's well because the 60 or 90 day window.
miggs
Uk England
yep bought a battery operated soldering iron the salesman was bigging it up i thought why not didnt even melt the solder
Joe69
Muncie, Indiana
I bought a Crapsman valve spring compressor. It flexed so bad that you couldn't get the retainers off. I returned it for a refund.
Joe
stricht8
I love the dremel. I've used it with one of those fiber backed cut off wheels to cleanly and precisely cut out sheetmetal on my cars in areas where a larger cutoff wheel wont fit.
