ratchet locks when torque applied
Jure
Croatia
i have bought brand new Unior 3/8 ratchet,used it for the first time ever,and locked on the first bolt,it works fine till i put some pressure/torque for a final tightening,then it locks and i cant move it to the left or right,i disassembled it,relubed and had the same issue...inside the ratchet it all looks fine,zero broken or worn out teeth,pawl and selector are good as well. like i said its brand new,and to make it work again after it locks you have to disassemble it and shake the gear...its 72 tooth ratchet,and inside it looks like this cman ratchet.
edit,no cheater bar on it.
G1GRANDEUR
yup, try use oil based.
when I use grease (Super Lube® Synthetic Greases) on Matco ratchet, it locks up.
J
Jure
Croatia
its not a grease,i know grease can lock up the fine tooth ratchet,i was using 10W40 motul i had at home. and cant warranty it because i have no bill of sale..
J
Jure
Croatia
does it still lock up with no lube?
yes,it has no factory lube at all when it locked the first time,locks even when washed with wd40 and zero lube...if there any way i put too much force on it? :headscrat i mean i have never ever had this type of issue even with a small 1/4 ratchet.
G1GRANDEUR
that's strange.
try with plate screws loose, maybe plate is being too tight.
country83
Any wear/roughness on the inside of the housing? I've seen teeth wear into the housing and cause that. Also where the pawl goes against the housing may be worn.
J
Jure
Croatia
i was not paying attention on the housing,ill check it
Greasymofo
dallas
Yeah thats why ill stick by my 24 tooth proto. The teeth are just huge. Never ever going to get damaged. Those little tiny teeth on that 72. Crazy to think they can hold all that pressure. But im not sure why it would be locking up. Sounds like when you put torque on it, the other bottom teeth are going upwards and catching the gear. Somehow or another
twertsy
Reedville, VA
Maybe try putting a fastener in a vise and leaving the cover off such that you can see what is happening? I'd wager it's not properly seated and driving the gear against something it's not supposed to engage with.
Swan
Winona, MN
Just had a similar (and common) issue with a brand new Gearwrench 3/8" 84 tooth ratchet. Cleaned and relubed it with light oil, still had problems. A forum member recommended running the ratchet with an extension bar in a drill to "break it in". This did not work for me but it has worked for others. I exchanged mine for another and the new one is great. New tools should work straight out of the box.
Zrexxer
Pflugerville, TX
Sounds as if it's just out of spec. One of those unfortunate cases where a defective product makes it through to the consumer. The defect rate might be 1/10000 of 1%, but all that's moot when you're the one that gets the bad ratchet.
Loscaldazar
Is this actually an Apex ratchet? Certainly looks like it.
The pawl also says 84 on it, and I wonder if you have a mismatched pawl/gear. Apex is know for that already....
Syntax_Error
Des Moines, IA
Wow good eye:eyecrazy: I would be interested to know if this is the actual cause of the problem. Does somebody have one of these ratchets on hand they can look at the pawl?
CatSplat
Alberta
Wait a minute, does it or does it not say 84 - 1/2
The OP mentions in his last sentence that the innards of his ratchet just look like the innards of the wrench pictured, which is a Craftsman - the image came from this page. That's not an actual picture of his ratchet.
J
Jure
Croatia
+1 this is ratchet i'm talking about
otis66
Grip the ratchet at the drive end, I usually put an extension on the drive in. And then spin the ratchet around for a min or two going in each direction. This is what I did...Problem gone.
