i have bought brand new Unior 3/8 ratchet,used it for the first time ever,and locked on the first bolt,it works fine till i put some pressure/torque for a final tightening,then it locks and i cant move it to the left or right,i disassembled it,relubed and had the same issue...inside the ratchet it all looks fine,zero broken or worn out teeth,pawl and selector are good as well. like i said its brand new,and to make it work again after it locks you have to disassemble it and shake the gear...its 72 tooth ratchet,and inside it looks like this cman ratchet.
edit,no cheater bar on it.
i mean i have never ever had this type of issue even with a small 1/4 ratchet.
I would be interested to know if this is the actual cause of the problem. Does somebody have one of these ratchets on hand they can look at the pawl?
