Home made metal brake.
LXCam
WOW bud, you put some major effort into that unit. Very nice!
Whiskeymike
Austin, TX
Awesome build! Can you talk through how you engineered the clamp vice ends? What components did you use to make them? (All thread, 2 nuts, welded to plate?) Is the box up top for weight in clamping down or just rigidity in vertical flex across the brake?
T
tlmartin84
West Virginia
I designed it myself.
6.5' of 16 guage. Will bend thicker shorter sections.
The blade is 1/2" x 4. I had it cut the same as a cutting edge, the heat distorted. So me, a grinder, 2-7" wheels and some clean up spent half a day together cutting the edge down.
The real neat parts (handles, turn handles, gussets) I all designed in CAD and had plasma cut.
The table top is a piece of HP14x70 piling that we use in construction. The bows were scrap pieces I had lying around. The bolts are all 7/8" left over stuff from our bridge construction. The springs were from Fastenal, the highest rated size I could find. The hinges were 7/8" bolts from same place.
The member 2x6 is turned upright for strength, again this was leftover from something else I had.
iajonesy
Iowa
That's as nice as any store bought brake I've seen in a while. Great job.You could sell those easily.
Mike
T
tlmartin84
West Virginia
Well I tacked it together prior to welding. Most of the stuff was thick enough that warpage was not a large issue.
I did have a few areas that warped, I had to heat and cool them with a torch until I got them into an acceptable tolerance.
58HalfCab
AWESOME! I built my own brake as well with some scraps I had laying around. I Like yours much more! Thanks for sharing.
[/URL][/IMG]
[/URL][/IMG]
Built an axle rack on the back and put it on some casters.
[/URL][/IMG]
Loaded with Dana44s
[/URL][/IMG]
Train
Alberta, Canada
So for anyone who has built one of these. Do you have any tips for getting the pivot points lined up perfectly?
