Nico's Single Detailing Garage
nicobkn
Montreal CAN
Hello everyone,
I'm back at it, again.. I'm sure some of you might remember my 20x20 Detailing thread. I put a tremendous amount of work in there and just when it was about to be 100% ready I decided it was time to move into my own place with my lovely girlfriend and our dog Pancho.
Here are some pics of my previous build. I did everything except for the tiles, I'm an apprentice electrician and I consider myself to be somewhat of a handyman
So what's next ? My new garage is 21x11 with a bump in the corner which is actually pretty helpful to store my tools and products.
Here are some pics of when we first moved in
I decided to start by adding some much needed lighting
Next was the floors
My main goal was to protect the cement from absorbing water when doing washes in the garage. I got a good deal on the paint from one of my clients who purchased the materials and never got around doing it. I rented the big polisher with the diamond pads to sand down the floor and applied a primer ( i think it was just acid) I spent around $300 on everything and sadly it's already peeling around the high traffic areas. So i'll have to find another solution. I also thought about using epoxy but since both of our cars have studded tires I'm pretty sure it will eventually peel off. At this point I'm leaning towards racedeck tiles.
Next up was making room for my 60G compressor, so what best than under the staircase ?
This area was a mess, the builder just "threw" everything under the staircase so there was a lot of wasted space
As you can see there is a lot of square footage wasted there, hard access too because of the central vacuum.
Out we go!
The water faucet was also " on the way"
The water tank was a good 2' away from the staircase so I modified the PEX piping and pushed it all the way in the back
From this
To this
First time framing a door, thanks for the help YouTube!
Once the tank was done I continued with the vacuum
Framing the new wall and doing some plumbing
Gyprock, the fitting at the top wasn't the best, had to do it all on my own
Sink will be going on top and hose at the bottom ( couln't find a blue and red faucet, will replace the handle after)
And first coat of filler
My next project was adding a shelf on the back wall so I can store my products. I have a bunch of 5g size containers I needed to find a place for so I built this shelf.
Went from this
To this
I also added a retractable cord reel I got from home depot. I was able to fish the power using some existing holes I used to fish the rest of the garage
And last but not least! Finally getting the walls ready for some paint! Most of them are ready for primer
Ready for primer
Dan in Pasadena
Pasadena, CA
Nico,
Very nice work so far.
Since you have a single with a side shop area I thought you might like to see photos I've saved as "Best 1 Car Ever" - at least it is to me so far. It's shaped much like yours so I thought you might like to see it:
Dan in Pasadena
Pasadena, CA
Oh, and PS: Maybe move the electric cord reel over to the same ceiling joist the receptacle is screwed to? The cord fully extended like that "pings" my OCD. not criticizing, just saying...
lilcraigford
Portland, ME
Nico - I am partial to efficient small spaces so I'll be watching this one with interest. I can appreciate going the extra mile to redo under the stairwell to utilize every bit of space! Judging by your first garage (really like the tiled floor) this'll be really nice when it is done.
Dan - Gorgeous Cobra! Did you build it? The first thing that caught my eye was the center mounted reverse light. Anywhere online where I can see more?
lilcraigford
Portland, ME
Yeah, as a matter of fact I did.:lol:
Nah, it's not my car and not my garage. I found those pictures here on GJ but I honestly forget whose it was.
"I thought you might like to see photos I've saved..."
Oh boy, I need to pay a little more attention. Obviously I was distracted by the Cobra.:D
tprice14
Nashville, TN
I really had my doubts when I first saw the space but after you put the lights in, it really changed everything.
Which brings me to my question, what lights did you use and do you think YouTube could teach me to install them?
Oh, and great job on your last shop. I have saved your pics to mimic the tiling. Hope the next space turns out as good or better.
N
nicobkn
Montreal CAN
Looking good I'm in st Hubert I'd love to have my wife's car detailed I'll give you a call
Take care
Sounds good! I'm located in Ile Perrot.
Nico,
Thanks for the photos Dan. As far as the reel goes, the receptacle if "floating" in the ceiling. I used an "F Clip" box which allows me to put a box without the need of a joist or stud. I put my box right in the middle of the garage and my reel on the closest joist, I didn't want to put any type of anchor since i'll most likely pull on this thing hard when needed!
Thank you! the porcelain tile it's holding great so far, my father really likes it.
Great job so far.
Thank you!
About time you have this thread set-up haha. Looks great Nico. I'll be checking back for updates.
I know eh! haha!
Nice work!
Thank you!
Very nice use of space.
Thank you!
Looking forward to seeing more updates! Subscribed.
Thanks Budo!
Thanks! These lights were collecting dust at my parent's shed. These come with a small cord so you can plug them directly on a receptacle. I modified them a bit and got rid of the cords. They are only worth $20 around here. There are a bunch of videos on youtube. If you'd like I can guide you on the install, it's pretty simple, send me a PM.
N
nicobkn
Montreal CAN
More updates!
I forgot to post these pictures. Here is some progress of what's going on under the staircase:
I tested my compressor and it fits perfectly in there
In order to bring the noise down I installed some insulation and also added a 1/2" gyprock sheet.
I also installed my door. Is not perfect, but for my first time doing it I think it turned out acceptable
I'm really proud of this filler patch I did. The lower right section of the wall needed a lot of work, I was able to bring it back and it looks perfect now. Notice the new receptacles! I added 3 on the left side and 4 on the right side of the garage. I covered them with masking tape before applying primer
And finally some much needed primer!
I managed to do all walls with one coat of primer. The ceiling will need more work since I have to remove all the fluorescent fixtures, or perhaps I may just cut around them?​
N
nicobkn
Montreal CAN
^Yup!
I thought about using corrugated plastic months ago but i dropped the idea. I went to Ottawa to meet up with a friend who details cars and he installed these panels in the wash area. It looked really good so I decided to get them.
I also got these nice roofing screws that come with a washer and a rubber seal. I'll be sealing between panels with white silicon to make the walls 100% waterproof.
ILLuSioNz X
Great progress, I've always toyed with the idea of hiding an aircompressor away in an insulated closet myself, let me know how much it helps with the noise.
OJ Bartley
Toronto, ON
Great job Nico, the place is starting to look really nice.
I'm not sure how the regulations are for this stuff, but does your relocated water tank have enough room around it for access? I seem to remember something about a minimum distance from walls or something like that. I'm sure you're aware of stuff like that and know what to look for, being an electrician. Just wanted to mention it in case.
Have you had any (FM) radio reception problems after installing your new lights? I'd like to do something very similar in my single, and frequently read about the new electronic ballasts killing reception.
I'm also keen on seeing small spaces develop, so I'll be watching for updates!
N
nicobkn
Montreal CAN
/\ Does your buddy run a company or just do it for friends?
He's the owner of http://www.upperclassdetailing.com , he's a really nice guy
I will! I was at 112 DB before adding the door and insulation. I will take another reading once it's complete.
I'm not sure about any laws. I only pushed back around 1.5-2ft. There access to the electrical connections in front of it and the pipes are still accessible at the top. I'm getting a new this summer since this one is almost 10 years old.
Hey Nico, is there a reason you are not considering putting down tile in this garage?
Hey! I don't have the time or the money for it at the moment. Also, i'm not planing to stay here for too long so I don't think it would be wise to spend that kind of money
N
nicobkn
Montreal CAN
My father came over to give me a hand with the installation of the corrugated plastic. We finished all the walls. There is still more work that needs to be done (adding more screws & sealing edges with silicon)
Please ignore the mess
dubber
Canada's Capital
Very cool. Thought you were only going to do lower half of the wall. Eliminates painting haha. Nice reflective shine which is a sweet side benefit.
N
nicobkn
Montreal CAN
Yeah i thought about only doing half but then i changed my mind.
So i finally finished the ceiling, what a PITA that was! Cutting around the lights, garage opener and heater was not fun. I picked up a Stelpro Spider, nice little unit @ 4KW, i'll post a picture on my next update.
The ceiling came out nice, had some extra paint from my previous garage so i saved a bit of money there.
I also did a major clean up on my toolbox, here are some pics
More to come!
Ryanble
chitown
Hey great work! I just finished this thread and feel like we were left hanging! Hope you comeback and update.
