Proto tool socket set issues.
Strouty
Southern Maine
With the replacement cost of 1" drive sockets + USPS flat rate boxes that's a No Brainer.
I had not really thought about the flat rate boxes at the time. I am still worried that they won't warranty them because of me using a wire brush on them.
Ruger_556
I'd just mail them in include a note saying you had to because they were peeling :dunno: I have a local dealer that handles it for me but the only bad things I've ever heard of their mail in warranty is from the people who couldn't be bothered to mail the tool in like Proto wanted...
Strouty
Southern Maine
Total thread jacking….
I took some pictures of them before I wire wheeled them, I think I sliced two fingers and a couple of places on my palm. The one I picked up was so sharp I did not know I had cut myself until I actually saw blood.
OutsideMachinist
Norfolk, VA
Thats the way they are supposed to be sir. Warranty and you will get the same thing. You would only be wasting your time and theirs. -To the OP
Kirbot
New Jersey
I kind of think I would have sprung the $10 to mail them in, and not screwed with the wire brush... :dunno:
I'll go with Ruger though... Include a note and hope for the best.
Strouty
Southern Maine
I had a job that I needed them for and was worried about a long turn around. After wire wheeling them, they were fine to handle, so I kind of forgot about them. This thread refreshed my memory.
It would take a few boxes, there is about a dozen of them that were peeling. Some worse than others.
shouse
Thanks guys. Sorry for getting my ******* in a bunch as well. I appreciate the wealth of information on this board, I guess my n00bness really came out on this one. Looks like I'm good to go. Thanks again. Still funny the grainger rep must not have known what a pin retention lock was either.
TOOL FANATIK
Bennington, VT
Generally, 3/4" drive and up isn't built to be pretty. A lot of my 3/4" stuff is black oxide. I keep it pretty much dripping in oil. My 3/4" chrome stuff (Proto, Wright, and Williams) is satin and is very rough. Nobody buys 3/4" for the looks - it's to get the job done. I think it does have a beauty of its own.[/QUOTE]
EXACTLY. they are typically farm or industrial.( guys who aint putting their tools back in their special places when theyre done, or even wiping the oil or s#$t off ) the processes they use to make these and 1" dr tools are different from your smaller drive tools im sure. as long as theyre strong and take a beating, thats 3/4 drive enough for me... and also, to the op, if you cant learn to love youre pin detent, ill trade you my friction ball 3/4 stuff. when youre socket or extension or both keep flying off of each other and the driver, youll be begging me for your s$%^ back. just keep a sturdy pick with them and you should be all set. good luck!
Zrexxer
Pflugerville, TX
Just for your information, Satin finishes are supposed to have some bite to them, it makes them easier to handle with greasy mits. If you desire smooth, glossy, easy to clean finishes you should buy Chrome finished tools.
Just to be clear, those tools are chrome. Chrome is a plated finish. Whatever the underlying surface is like will be reflected through into that plated finish. If it's highly polished, the plated surface will be highly polished. If it's as-forged, the plated surface will not be smooth or shiny. But it's ALL chrome.
Pretty much the only alternative finish for drive tools like this is black oxide.
Hiball
Missery
My apologies, I should have worded it as "polished chrome", @Op there is still nothing wrong with the finish characteristics of your Proto extensions.
Zrexxer
Pflugerville, TX
I know you understood the difference Hiball, I just thought the terminology might be confusing to the OP.
RV77
Seattle
Shouse - about the pins in the extensions and ratchet......They do this to prevent a socket or extension from flying off while being used at a weird angle or with a impact gun ( Im guilty too )
Yea its inconvienent to use a small screwdriver to remove them but think about taking a 1-7/8" socket to the teeth after it flies off while using an impact...
EXPERT
Hi everybody, here is another fan of hand tools!
SOme answers to the thread:
a) Europeans like finishings that do not glare (they consider them more industrial, rough...tools are things for men!)
b) Americans like shiny finishings (tools are not only for men, they must show perfectness and must be beauty, they are the few jewels men can enjoy)
Of course this is stereotyping, but there is some truth in it.
Having said that, one thing is coating and another is finishing (nomenclature can vary, but it is usually like this):
a) Cheapest chrome plating finishing is "matt chrome". Forged pieces are cleaned and chrome plated. Surface is rough. Due to this reason, plating chips off easier. Most of Gedore tools on the pictures shown are this kind of finishing (which is hardly understandable...).
b) After it comes "satin matt chrome". Forged pieces are sandblasted, then chrome plated. The finishing is matt (not shiny) but not rough. Plating is more resistant.
c) Then "mirror polished chrome". Forged pieces are finely polished, then plated: the finishing is smooth shiny. Plating is even more resistant.
d) There is a more expensive finishing called "fine satin matt chrome" or "aerospace satin chrome": forged pieces are finely polished for deleting any surface imperfection (as best tools should be), but in order to comply with European "taste" they are after very finely sandblasted to take out the glaring shiny finishing, and after chrome plated. This is the most expensice chrome plating, and most resistant.
I guess there may be more coatings and finishings, but these are most used, but costs and (most important) benefits are unknown to most users.
Hope it helped!:thumbup:
decableguy2000
I had good experience with Proto warranty services. I had an old bet up 3/8" ratchet and went to Grainger and the gave me a rebuild kit to bad the chrome was chipped and peeling. I called Proto and they said to mail it in with a return address enclosed and received a new one today. I think it was right at week door to door.
Jeremy
ephotrod
Texas
Its a tool to get a job done, use them don't cry over the,. They will do the job and finish the job without giving you much hassle. Please note you bought them used, you should have checked the condition and finish at the time of purchase.
logical
Northern fringe of the Motor City Suburbs
None of that explains the whole arm pit hair thing.
