SkeeterAg99
Just finished the 24x30 pole barn and ready to get electric to it. I'm gonna do the labor and let someone qualified hook the boxes up and tie into house, but I can manage the runs. I have plenty 12-2 yellow Romeo for inside building. Gonna have one aide plugs on one breaker, other side on another breaker, 3 rows lights each row seperate switch. My question is I have one roll of 12-2 uf-b and trying to decide what I need to run from house to shop. The total run is 75 foot pretty unobstructed maybe a 45 turn around a tree. I want it to be in conduit 18 inches deep.
1. What cable should I run from house to shop and have already waiting for electrician to just tie in and hook up. I would like to have a 220 also but it's not entirely necessary.
2. Will the uf-b 12-2 I have suffice for the run in conduit, or should I run something different(heard its direct burial and can't go in conduit). I'm only familiar with standard inside runs of 12-2 and 14-2. Trying to save a dollar doing the hard labor. Any suggestions. I'm Not an electrician but I can sure do some labor.
3. I will lay some 1/4 inch pvc along with 1/2 inch and put low voltage runs for phone cable and Alarm. Couple runs Cat 5e should do for this correct?
4. Anyone recommend a panel to buy. Square d I know is good.
Let's See if pic works- here's the run 75ft about. Panel will b right behind door. U can see where my main line comes in that I just filled in with topsoil. Thanks for any insight and suggestions!
Jeremy
Jeremy
