Beam above garage is sagging...
Pen & Wrench
Huron, SD
I agree, you should be able to get out of the contract if you want to, based on that undisclosed (even if they say they didn't know) structural problem. How bad do you want to buy the home? Is the seller willing to fix it to a spec that really solves the problem? Or do want to negotiate a reduced price and fix it yourself? If there's financing involved, the lender may only agree to a certain way. You sure don't need to pay for that problem yourself.
yeldogt
You will not have enough room for two doors -- those garages were narrow to begin with.
Do yourself a favor if this is a house you are going to live in --- price the cost of repairs (done correctly) into the purchase price. When you go and sell, the next guy will. If you do try and fix incorrectly -- you wasted your money .... you will not get any value out of it when you go to sell.
I wanted good rent and top dollar when I eventually sold - I fixed them. When a house needs work to its bones many will not even look ... unless this house is all about the location you have to price the problems into the asking price.
Do you know a contractor? I have paid contractors to come with me to look over a house to give me rough estimates. Doing things correctly is expensive .. until you look at the long term cost of doing it incorrectly.
Given the correct purchase price this is not a huge problem -- it does look like a strange lot .. and the concrete on the drive is all broken -- did the ground shift?
JACDes
IL
16' less 1' for post and framing = 15' / 2 = 7.5'
You CAN get custom width doors. if you need an extra 6" to pull straight into a stall you must be a terrible driver.
My garage is 4 car the doors are 15' wide, originally they were 14' !
JACDes
IL
unless you are trying to park a trailer in there. most any car, SUV, or pick up truck will fit thru a 90" wide opening.
JACDes
IL
otherwise if a post is a problem and you really need the garage door width then you have to shore the floor above, remove the old header and replace it with new LVL beam or a steel beam. THAT SHOULD BE SIZED BY AN ARCHITECT OR ENGINEER. don't leave this up to a contractor to figure out...80% of the time they will get it wrong..
JACDes
IL
regardless of the solution this is not a deal breaker if you want the home... use it to negotiate the price. otherwise use it to back out of your deal.
CNGsaves
KS and OK
^ ^ ^ No one would want to jerry rig a pole in middle of 16 ft garage door to make it easier on Seller of house to get off the hook, and improvise with 2 crappy narrow garage doors !!
Do it once, Do it Right !! OP needs to pound DOWN the price by $10K or whatever is the highest quote he can get for repairing the sagging header.
There WILL be other hidden problems in that house . . . I can guarantee it !! ;)
Bubbles
Look at your eave.. It's chopped up for the stove instead of extending it out.
What is on your garage door spring?
Blue
Northern Illinois
Also the flashing inside over your window?
Speaking of other problems, has anyone else noticed the handi-box without a cover in the seventh picture?
Chimney flue needs tie-downs as it's unsupported. Only should need one Dish !!
Good thing that house had been owned by someone who really knew how to fix things!! Thankfully it wasn't owned by one of those young whipper-snappers who didn't know how to fix anything!
http://garagejournal.com/forum/showthread.php?t=274488&highlight=tinker&showall=1
Platonic Solid
CT-USA
Could also be structural termite damage. Especially difficult to deal with in houses with cinder block foundations.
Gojeremy
With the sag, landscape, and even the driveway looks to be in rough condition, i would walk.
kbs2244
I second big bad dad's opinion.
And I would keep shopping.
You would be buying both a headache and a heartache.
OzarkMan
Ozark Missouri
The OP must have passed on this house. There was nothing good about the situation and I'm sure the seller wasn't going to deal with fixing it either.
6768rogues
Western NY
I was in the contracting business for many years. I have seen that situation so many times that it is almost safe to say that from that era, they all sag. Even the ones with only a roof and no second floor above sag. It might sag a little more over the next 30 years, but will probably never fail unless it has damage from insects or rot. Dimensional lumber is not stiff, it flexes. To reduce sag, the lumber needs to be big or be an engineered piece.
I would jack it up, put a wall under it, make a Man Cave inside and park outdoors until a separate garage can be built.
JACDes
IL
I'm sorry, I did not know your solution was the only and best one, when I need your approval I will be sure to ask for it. :thumbup:
JACDes
IL
I see a lot of those same models in my area. They all sag, but never saw one collapse!:thumbup:
give it another 50 years, by then the rest of the house will be shot.
or just have a hoarder move in and load up that bedroom for a dramatic effect.
bczygan
DETROIT! Arsenal of Scrappers
Just a note.
The right term is deflect. An old woman's ***** sag.
All materials deflect under load, even just the load of their own weight.
What is seen here is deflection that is over an acceptable limit, because the builder did not properly design the beam.
JACDes
IL
Just a note.
yes, the moment capacity has exceeded the acceptable deflection limit for this beam, because the beam is undersized for the span & the loads imposed on it. :thumbup:
the only 2 viable solutions are 1) reduce the span of the existing beam or
2) replace the beam with one designed for the intended loads and span.
yeldogt
IMO -- the problem with the house was the wall out front ... and the chimney on the right.
The garage is an easy fix -- not the bad lot. With that wall its even bad for a rental property.
