Lincoln AC welder, 50A breaker, 50A plug on a 12 cord and no secondary thermal. All the secondary is designed for shorts to 50 and protected from overload by duty cycle. A 200 mig, 12 cord, 50A plug and breaker but lots of fine internal wiring, goes to cord to double pole switch to thermal and if one really reads the instruction manual will see that the machine only needs a 14 wire to operate but,,,,,,,,,,,,,, once you do this must change the breaker to 30.
My steamer, comes with 5 hp motor, 10 wire, 30A plug with instruction for 30A breaker. The only secondary is on the furnace motor and they spec leads which are normally 16 to 14 for this application despite the draw being 1/2 the amp it would be at 120,,, not allowed to connect 16 wire above 20A
