I'm selling my 220V 60 gallon compressor since my new house doesn't have 220V in the garage and I don't have the money to wire it up.
I found a 120V from Harbor Freight that seems to have the best specifications I can find for a 120V. I noticed that there are two of the same compressor, so can someone help spot the differences and help me make a decision if one is better than the other?
http://www.harborfreight.com/29-gal-2-hp-150-psi-cast-iron-vertical-air-compressor-69865.html
http://www.harborfreight.com/29-gal-2-hp-150-psi-cast-iron-vertical-air-compressor-61489.html
They flow the same CFM and have the same tank size, but the dimensions are slightly different. Also one draws slightly more amperage. I also noticed that one has a CSA cert and the other an ETL, but I don't think that means anything...
Just trying to figure out what the best choice would be or even why they would carry two nearly identical compressors.
I'm waiting for the 25% off coupon to surface and then I'm going to bite on this.
