KP: i have a stand where i use the bolt in the post to raise and lower the height that is a two piece arrangement. so if i took it out and put another grinder or vise in it's place with the same size 3 inch tube that should work. then you'd have gravity holding it in place and the screw could tighten it down. is that what you mean or do you have any pictures?
Kaz: I probably posted your table all over GJ more than i did Alan's, but they are both my favorites besides that white one i am going to build now that i own the materials.
thanks for seeing the posts. how's your table working for you and what's the biggest vise you've put in that hitch type holder?
this is a very nice looking table
Brent: thanks for posting your Craftsman block grinder quartet again. are they still with same wheels you had on them originally or do tell if you changed any of them?
McB: i think this is the member you are mentioning that can weld up table bases like the best of them.
http://www.garagejournal.com/forum/showthread.php?t=272772
A 70 lb Manhole cover and a craigeslist Columbian with small welding table.
I am also building a belt/disc grinder . I still need to build the tool rest for the disc grinder.
You don't realize how bad you need a belt grinder until you need one to build your belt grinder.![]()
I get 431 pounds for your plates, I think your are a little light.
ALL: I borrowed this from a post by one of our members. it's made of wood which I might not build, but i think it's a great idea.
he has several of his gun loading accessories mounted to boards that slide in and out easily and if he only needs an empty bench he has a blank to slide in.
any other great ideas please post even if it's not yours and you saw it on our forum, online or in a friend's garage.
MD: sorry I didn't find it on a build thread and it was on a thread about wall cabinets which i thought was interesting. it was this member's bench (Narddog) in case you want to look it up. Maybe he did a build thread and if you find it can you post up the link back here on this thread?
i did think it was a great idea and bench.
