signcrafter
- Joined
- May 9, 2012
- Messages
- 12,636
After this incident, http://www.garagejournal.com/forum/showthread.php?t=282668, I want to pick up a stud extractor to help pull out broken studs. Where the downpipe connects to the turbo it has 4 studs in the turbo and nuts to hold the downpipe onto the turbo. I went to remove the nuts and the studs snapped off leaving about 1/2" sticking out of the turbo flange. I was able to remove one by welding a nut on it. Another one I tried to use a bolt grip and it snapped below the surface of the turbo flange. So I need to drill that one now.
But others recommended a stud extractor to get them out instead of welding nuts onto them. So looking to pick up a set to have on hand for times this happens, can never have enough options for crappy situations like this. I have been doing some looking and came across a few different options and wondering which one is best? Do these work good on broken studs that have 1/2" or so sticking out?
http://www.amazon.com/dp/B00265M8N4/?tag=atomicindus08-20
http://www.amazon.com/dp/B000K1KHB6/?tag=atomicindus08-20
Is one type better then the other? Because when you need to use these you are already having a bad day with broken fasteners so want to make sure what I get will be the best chance to make my day better. Open to other options as well.
