Outlander
Quebec, Canada
Dragged charger, supplies and tools into the house and replaced alligator clips in the comfort of the warm kitchen. Took the Outlander to the dealer to get 2 new keys programmed so I can go out for a ride tomorrow.
k-os
WI
Moved the workbench down to the corner, mounted the lights under the wall cabinets, mounted the TV mount (waiting on VESA adapter), and put up the dry-erase board.
56vette461
Pulled out my old school Mac 110 mini chain saw that I prepped for short-term storage in 1997. It was in it's original plastic carry case with a dry fuel tank, small amount of chain oil in the reservoir, and wrapped with an oil cloth and plastic.
After going through the saw and checking the spark plug, I filled it with fresh fuel, chain oil and with the assist of a little shot of starting fluid it started up. Made some test cuts on a tree we are removing. Tomorrow it gets its first real use in a long time. Nothing like old school quality tools!! :beer:
mdbeck1
Norman, OK
More clean up and straighten up. Had some friends over for dinner and one of my buds helped me check out some electric motors (he's a retired AGE mechanic). So I had 5 electric motors sitting there. One is DEAD, One is LIVE, two need to be cleaned real well and will probably function after that and the last one we didn't check (220 VAC).
Krokodil
South Africa
Welded an allen key in the front diff sump plug of my Toyota. Struggled the whole of yesterday morning to get it out until it stripped. I guess the heat of welding + a proper fit on the allen key helped to get it out at last!
67carl
California
I'm in the process of rebuilding my RS headlight assembly, including upgrading the wiring and installing halogen lights. While waiting on parts (every part is available for this car, but you just can't pop on down to Autozone to get it) I'm doing two small related projects.
I write our club newsletter so I thought all these would be good projects to share...
67carl
California
Actually it's three side projects whike waiting on parts...:eek: damn projects seem to multiply like bunnies!
This is a new wiring harness to increase the volts getting to the new halogens...
firecracker
Lancs UK
Had a sort out in my man cave, had a fire going in the barrel wood stove which got the temp up from 3 to15 C. Got through a fare chunk of logs.:dunno:
Jimmy_B
Washed, buffed and waxed my wife's old POS. She's happy.
j p smith
Glendale, Arizona
Working on finishing up this windmill project, hoping to deliver in 2 weeks to Apache Junction.
zcar751
Knoxville, TN
After, polishing the wheels on the Puma I looked at the drivers side which I did first and decided to re due the drivers side. I guess practice makes perfect, I just wish I perfected the techneque on the first wheel instead of the third.:lol_hitti
View media item 48686
rmsg0040
Toronto
Was far away from home today, driving down the highway and noticed the battery voltage was low, got scared I was going to shut down on the highway, floored it to partsource and got an alternator (knew it was on its way out). Voltage was holding at around 11-11.5V until I got home.
oil change on mom's car, alternator swap on mine
LWW
SF Bay
Replace/Repaired 2 sprinklers and put on a new mailbox. I'm supposed to be doing annual reviews but I so hate the bureaucracy and the paperwork that goes with it.
LWW
SF Bay
And my neighbor just told my wife that the post on my mailbox isn't plumb... Must have settled after I put it in... Damnit!
j p smith
Glendale, Arizona
Got her done, the 1921 Aermotor is assembled! Little bit of punch list next weekend and delivery the following, Glad this is going off my project list.
Trikerider
Parma NY
Mounted 2 flag holders on each corner of the "Garage Mahal" .I display all Military flags + POW flag on all holidays. Also screwed in 50 state liscense plates on my joists.Some day I'm gonna learn how to post photos. Is that work or fun?
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
Oooooooooh, I love the finish on that vise!!! ^^^
What a year already!!! I've been so swamped I barely have time for anything but I realized I haven't shared any Powder **** for awhile.
These were the highlight of the month for both the customer and me -- 42.15 hours (woo hoo, what a payday!!!) and he's jazzed with the results. The front clip behind it is the same guy's other grille still to restore -- he's got five cars -- but it provides a good comparison from then and now. (Still trying to figure out the new phone; hopefully these pics aren't a half inch wide lol)
AR15Texan
AC Condenser Replacement in Hyundai Sonata
2012 Hyundai Sonata 2.0T with poor performing AC. I brought it into the dealership and they tell me it is empty of refrigerant. They want $790 to replace the condenser. Get it back and the AC no longer works. I charged it with nitrogen and see it is leaking out the condenser. The dealership claims the condenser must have been damage by road debris. I bought a replacement condenser for $65, 30-lb of R134a refrigerant for $120, and some PAG oil.
Front bumper removal
Front bumper
Damaged Condenser
Rock damage, yeah right. Looks like screwdriver induced damage to me.
Removing Condenser
Removing Compressor
Compressor out
Flush kit:
Evacuating the system
Manifold gauge setup
Vacuum system down to 64 microns. Held for 30-mins with a rise to 74 micron
Valve core removal tools and Snap-On leak detector
Hesketh
Scotland
Well, at last managed to pull "the unit" out of the jag.
I am so glad I got the engine leveler as other wise this job really would have been a bit of a pain. Battery impact driver made short work of the adjustments.
Now just to fit the new gear box and return it all.
polexican23
burbs-Illinois
Had the electrian over. Orginally it was to add a 220 and some lighting to the garage. Turned into rewiring half my house because 2 general light circuits were overloaded. 15amp breakers showing 19amps. Come to find out EVERY outlet and light was on 1 15amp circuit. That included the garage door opener.
Nice unexpected $400 out of my pocket and 5 hours of work.
DonPowers
On The Hair At The End Of The Dog's Tail
Local lumber yard / building supply delivered another load of sheetrock and insulation for the upstairs of my garage. The young feller driving the truck thanked me for helping him carry the stuff upstairs, said that lots of times nobody helps him. Couldn't believe it, told him that it was me that appreciated the help.
Because I have an account with them, not only do I get a contractor discount, I get free delivery for orders of $275 or more and help getting materials upstairs or wherever I want it placed. Can't beat small town customer service.
Trey T
Houston, TX
My garage is such a mess after I sold my 10ft long workbench and tool chest. After sourcing new storage cabinets and work bench, I finally assembled my workbench. Also got my small Lista cabinet on casters.
I modified the Edsal 30" wide legs to properly accept the Footmaster GD40S adjustable casters. The workbench is 37.5" tall now and should be very versatile.
Still a lot of work to clean up the mess to park an additional car in there; it's a two-car garage.
LWW
SF Bay
Re: AC Condenser Replacement in Hyundai Sonata
[/URL][/IMG]
That is DEFINITELY not from road debris. For future reference, whenever possible CHECK REPAIRS FROM ANY SHOP BEFORE YOU LEAVE THE PARKING LOT!
If you had tested the AC while sitting in their parking lot it would have been very difficult for them to claim road debris damage. Take it to them and ask them if they want to refund your money. If not, out the dealer, the service writer and if you can get the name of the mechanic on social media, this and any automotive forums you frequent.
If nothing else, maybe it will save another customer from their shoddy "service".
Sorry, I see this too many times in my own shop when we have to fix someone else's crappy work and it kills me to have to charge the customer because to fix the incompetent repair attempt usually costs more than the original service.
With the power of the internet, yelp and crowd sourcing, we finally have the tools to fight back against these thieves.
