Questions for 4-3 romex?
Redwolf947
South East WI
Please note I am done with this project but have new questions at the end of this thread..
Going to be running 4-3 romex from basement up to the attic then over to garage down to sub-panel.. What type of staples/straps should I use?
I plan to drop the wire from the attic to the basement (seems the easiest course to take) can I install a conduit bell into the hole I drill to help keep the wires casing from getting messed up?
How hard would it be to run it thru the joists in the basement? I would only have to go thru 4 or 5 i think.. Any other pointers? Suggestions?
(As a note in my attic the ceiling joists run properly from the roof eves but they put another set of what I'd call joists running longways perpendicular to the others? I plan to attach this run to the latter.)
Please if any info is needed I'll do my best to provide it. looking for guidance please.
75gmck25
Alexandria, VA
I ran 6/3 romex for a kitchen range through my basement floor joists without any real difficulty. Just make sure the holes are a little bigger than the wiring, and snap a line across the joist to keep the holes lined up enough so that you can pull the wire through easier. I also used some wire pulling lubricant to reduce the friction on the jacket.
Do you have an open chase where you are running it to the attic? The point where the wiring changes direction 90 degrees (across to basement to attic) is the hardest to work with unless you have a helper. One person in the basement needs to pull the wire across through the joist and keep it from kinking or binding at the 90 degree turn, while someone else pulls it straight up to the attic.
There may be standard wire staples that would work for 4/3 wire, but there are also many sizes of screw-down u-shaped wire clamps. You only need a few clamps to hold it in place if most of the run is across through the joists.
Bruce
rockwithjason
Las Vegas
no need for fitting unless there are sharp metal edges that can cut the wire. wood or concrete are not much of a threat unless you try to fit 10lb of **** in a 1lb bag.
R
Redwolf947
South East WI
Bruce
Thanks for the reply.. I do have a great helper my GF she usually does pretty good and follows my direction... Good plan on snapping a line... Yes I'm going thru a wall cavity that I know there isn't anything else running thru. Going to drop a string with a weight on it to basement trying to measure so the holes line up should be easy.. Good deal on the clamps thanks..
R
Redwolf947
South East WI
They make oversized staples,or just use 2 hole pvc straps. Is this aluminum or copper wire
*The wire is Copper
Thanks, I was hoping to use the plastic 2 hole clamps/straps or the 1 1/4" plastic staples for PVC..
Its a 80+ foot run mostly in the attic. Maybe I'll post some pics this weekend.
R
Redwolf947
South East WI
So in other words make the damn holes big enough in the first place?
The wire is approx 1" in diameter, should I use 1 1/4" or 1 1/2" holes?
R
Redwolf947
South East WI
OK more questions. I figure I'll ask here and not start another thread. This is the last knockout I have for adding my sub-panel. Unless I move the existing work/sump pump outlet down under the main panel which is doable.
View media item 48881
OK another view. Please note the right most 1/2" conduit will be removed and transferred to the sub-panel to the left of the main.
View media item 48882
Kinda tight but can I run the cable out of the box and up to the joists without conduit like the previous owner did with the 8/3?
View media item 48883
Some of the wires you see that look kinda short will be removed soon too sense some go to the garage.
Any comments, suggestions, pictures of what you've done?
I can take pics if needed.. Thanks...
jvitez
Big Sky Country, Canada
The wire I bought is 4/3 Romex to run a 60a Sub in my garage. :thumbup:
Hold on a minute there Baba Looey. 4/3 Romex is good for 95 amps. If your subpanel load only requires 60 amps you'll be good with 6/3, which would be way easier for an 80 ft pull.
Correction: I was looking at the 90° column. 4/3 is good for 85 amps using the 75° column, and 70 amps using the 60° column.
R
Redwolf947
South East WI
sberry.. I wasn't sure about "protecting" the cable..
Let me ask this...... The previous person to do electrical work used short chunks of conduit to get the (nm-b) wire up to the joist cavity was that needed? Or could I mount a board above the boxes use a clamp then staple the wires to the board (using nm staples)?
R
Redwolf947
South East WI
Yea I see the 70a QO breaker @ $45 is twice the cost of a 60a @ $16 :wtf: ehh this way at least I know if I need a heaver load I can up the breaker to 70a.. I doubt I'll need that tho.
Baba Looey?? :headscrat
R
Redwolf947
South East WI
R
Redwolf947
South East WI
What size are the joists youre drilling through,Is the area readily accessable?
2x10 joists. I do work with wood in the basement occasionally.
I plan to run thru the joists in the basement routing up thru a wall and across attic. I'm still itchy from crawling around in the breezeway attic yesterday learning where I can drill holes to connect the two attics and trying to figure out where the existing wires run so I can pull them back thru.
I was thinking where the run exits into the garage at the ceiling putting in a short chunk of 1-1/4 in. sch 40 with a LB Non-Metallic Conduit Body then PVC conduit to the top of the box. Tho as I'm digging deeper in the the cleanup of the garage I'm finding more ways to run it I'll take pictures. I'm planning to take more pics along the way and maybe do a thread on it. It wont be as nice as some I've seen on here but Ehh I'll do what I can.
pattenp
Virginia - USA
It is permissible to run the #4 Romex along the bottom edges of the floor joist. You do not have to run it through bored holes unless you want to.
R
Redwolf947
South East WI
I had found that info while digging around in the NEC. I haven't decided If I'm going to go thru the trouble. I could always nail up a couple of 2x2 runners to protect it.
wyliesdiesels
Modesto, CA
NM-b wire ampacity is limited to the 60* c ampacity. So 4/3 NM-b can be protected with a max size OCPD of 70a...
Norcal
4/3 NM is sized from the sixty degree column as is all NM cable.
R
Redwolf947
South East WI
Ok I've been done with this project for a long time. I have recently changed my ceiling height and have a problem. Let me cut to the chase can I drill a 1" hole thru a double 2x6 rafter to run this 4/3 Romex safely to my subpanel?
simpler=better
Baltimore, Maryland
Probably. Center the hole in the 6" direction. In the long direction, DO NOT put the hole in the center 1/3 of the board.
If you're paranoid, sister it up. Use liquid nails and a handful of 3" deck screws to attach a 3ft or 4ft long section of 2x6 to the existing rafter, such that you will be drilling through a triple 2x6. It's probably not needed but would help me sleep at night (and I'm a hack).
theoldwizard1
SE MI
I think you have that backwards ! Ask any architect/structural engineer and they will tell you the stress on a loaded "beam" supported on each end are lowest in the center of the beam. The top edge is in compression and the bottom is in tension.
(WOW, some of the stuff from college 40+ years ago actually stuck !)
simpler=better
Baltimore, Maryland
Errr, you know what I meant! Don't drill it in a place that will snap :)
If you can run it without drilling anything, but come up short-would you be against throwing a junction box somewhere accessible? A 8x8 PVC box + some split nuts and rubber tape isn't too pricey
dave*99
Coastal NJ
IRC 502.8.1 which applies to floor joists in residential construction says no drilling in the center 1/3 of the joist span.
R
Redwolf947
South East WI
I'm not against that if I have to. Heck I have a box I could use. Thanks I'll keep that in mind. Hope I don't have to do it that way tho..
R
Redwolf947
South East WI
IRC 502.8.1 which applies to floor joists in residential construction says no drilling in the center 1/3 of the joist.
Yep some where I have that in a diagram form for floor joists. I need to know about rafters? I can't seem to find anything? I see in a lot of places people saying it shouldn't be done but I can't seem to find it in the NEC
dave*99
Coastal NJ
I think you need to look in the IRC not the NEC for that info. Also, I must say in reading this thread I mistakenly thought you were moving the cable in the photos from its position under the joists to bored holes in the joists.
It took a second read to figure out the photos do not apply to your latest question, which I think refers to a roof rafter not shown in the photos. Did I get that right this time?
R
Redwolf947
South East WI
That is correct. I'll snap a pic today if I can.
