spectralen
- Joined
- Mar 3, 2015
- Messages
- 10
Starting to rebuild. Would be great if someone knew what this was.
Thanks
Thanks
spectralen, the advice given is good as well as your "theory". I've got a couple of those of that vintage and the rear casters are through both support pieces and retained with snap rings. They are pricy according to Hiball and whoever changed yours went cheaper with the bolt in's. The allen head screw under the bolt removed is the access to the relief valve passage. You won't likely get it out. None of mine would come out. I'm guessing that the ram packing on yours is leather and the slotted threaded collar is used to tension leather seals, where most use O type rings. Your's is a bit older than mine likely. I purchased reseal kits from Hiball and it carries all the parts needed for all those similar to yours except the ram leather packing. He may have that model as well. You've got a couple of freeze plugs on either side of the valve in the main body to remove yet. Careful the order things come out!
Are both sides of the frame like this?
Did they maybe do that to work with different casters?
When you say leather, Is it a rubber over leather? The discs are rubber but almost look like they have a fraying of leather.
I was just going to flush with a transmission fluid and call the block area good and not take it all the way down, seeing it worked fine.
The Piston Seal is Leather with some Impregnated fillers, the Round Washer pieces are a combination of BunaN with some Fabric reinforcement and everything looks OEM outside of the Rear Casters Modifications and Frame trimming to accommodate.
Would you know if I can purchase the seals in the pictures by them selves and with a tank seal?
Thanks
So would I be looking for a kit for a Walker 93632 or 93633?Not Sure what you mean by Tank Seal, Im sure you can but you would be better off just buying a Kit and refreshing the Valve components along with Pump Seals.
There is a small seal where the tank came away from the block. It may have been silicone?
