Swivel Toolbox.. Never seen a toolbox like this
pi_guy
N/A
It seems neat.
But having 1 point of support might lead to issues
Two it looks like you loose space with the radius.
zkling
Sold only to the coolest kids.
We've addressed them here before.
I don't think a single person found a use for one.
I had a small bench top version.
It pisses you off just loading it let alone trying to use it.
:spit:
If you actually think about it, they take up more space and offer less storage capacity in use than a conventional rectangular drawer tool box.
neophyte
Pennsylvannia
:spit:
It really depends on how the proportions are laid out compared to a regular tool box.
If the drawers are really deep compared to their width, than you would lose a bunch of space due to the arc needed for the drawer to pivot open. The largest waste of space would be if the depth and width of the drawer were equal.
The wider the drawer is compared to its depth, the less space would be lost compared to a rectangular drawer. Some of the smaller truck and benchtop boxes the company makes, don't seem to have that much space loss.
Unfortunately it's hard to tell how much actual drawer space you really get with the boxes, since the manufacturer doesn't have blueprints showing drawer dimensions, or drawer swing, on their website. If they did it would be easier to tell whether the user would be losing appreciable drawer space compared to other boxes.
One disadvantage to these boxes would be if you purchase your tools in pre-made modules for storage since most modules are rectangular and would fit in the wedge shape. If you have fitted drawer foam custom made for your tools this would likely not be a problem, and the arc shape would likely fit graduated length wrench sets well.
The drawers to the Swivel units have an advantage in a messy workplace in the way they're made and designed. The lack of roller or friction bearings mean if something unpleasant gets spilled on your box when the drawers are opened, it's not going to get all over, and into the bearings, and the box would be far easier to thoroughly clean afterward. The same would be true of abrasive dust. Each of the drawers have a grease fitting to keep the pivot lubed.
If I have one main complaint with the design, it's that the empty wedge could have been used for a locker, possibly accessible from both side and rear it the box was used as a mobile unit. The manufacturer could have put some hooks or a pry bar rack in the space as an option.
I actually like the design but don't have the funds to purchase one at the moment. Plus I would probably be more interested in to half wide units rather than the double wide.
I presume those may be from a dealer since a couple of them are special order colors.
Another advantage is you wouldn't hear that vibrating metal drawer sound every time you open a drawer.
Oh, the boxes are made in Canada.
http://swivel.pro/index.php/about-us/gallery
<iframe width="560" height="315" src="https://www.youtube.com/embed/1ANg3oOXgs4" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/m90L0zmx6bQ" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/jj5hzk6H370" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/Ou8POizw7oQ" frameborder="0" allowfullscreen></iframe>
RunninOnEmpty
New England
So the weight of the tools is supported by some sort of hinge on one side of the drawer rather than proper slides on both sides? Plus it takes up a bunch of room. In my opinion, this entire idea is absolutely terrible.
mitusa
SW Oklahoma
My local Home Depot had that box a few months ago.....quiet and well built, but expensive.:sad:
4xdog
Santa Fe, NM
This looks like a solution to a problem we don't have.
Clever design, maybe, but you couldn't give me one. I'll take regular drawers, thank you.
arz71
Arkansas
I think it would be a great concept in the corner of a shop. Roll around tool caddy of sorts, when you can open it up wider.
I do not see the 'waste of space' that is far better than drawers on a mobile truck and much stronger than drawers being constantly jarred. I have never seen any mobile tool box survive very long with drawers.
Made in Canada if I had the extra money would like to have the roll around box for sure.
arz71
Arkansas
One thing it brings the wheels up with a lever, so it would be secure, seems like a neat concept.
Lifts up off the casters, so it is level and the thickness of the metal top seems pretty nice.
tedsters
sure is a different concept but i agree with a lot of others, sure is some wasted space and the idea of the single hinge point looks like it would be a problem somewhere down the road especially on the bigger boxes with more weight in them.
i don't really see myself where its a good idea i guess i would have to read up on them to see why or what the whole idea of it is except it looks neat or cool to someone, but not me
rick carpenter
Huntsville, East Texas
Looks to be a tremendous timesaver...
*You could open the drawers with one hand while still wrenching/welding/grinding with the other at the same time.
*If you had two facing each other, it could cut down by half on the time it takes to find that tool you put away but don't remember where.
RunninOnEmpty
New England
Yeah, I love to open my toolbox and look for tools while I'm grinding. I may be missing a few fingers from last time I tried it, but I saved at least 10 seconds doing it. Totally worth it.
Bruce Lancaster
!! Reminds me of when a visitor noticed that I had a drill, an angle grinder, and a soldering gun plugged into one outlet..."Ohmygawd...unplug those!!! You'll burn down your house with all of that running on one circuit!!!"
Yeah, grinder in left hand, drill in right, soldering iron in my teeth as some poor chunk of metal cowers under my attack...
Anyway, only use for the swivel box I see is as a borrowing deterrant. Move the handles to the wrong side of each segment, and it will stop your dumber friends from opening the thing and borrowing your pliers...
