linear actuator
Diggla
Has anyone use one to open and close a custom built carriage door?
willy (traer)
Just ran across this - wouldnt think it would be too hard to do....
Bondo
Greenfield, Maine
Ayuh,.... 'n Surplus Center offers quite a few of 'em,...
With their shorter action, I'd think mountin' by the door's hinges oughta work,...
D
Diggla
Need ceiling clearence so over head door opener no gd. Of course thats the easy option lol
D
Diggla
I just might scrap the actuator plan because i cannot link it to my home automation. My question is if I use 2 openers in the video, put each one inline with the door jamb (need ceiling clearance for lift) and keep the pivot connection the same on the door would it work?
Playwme
The Lucky Country Down Under
Why not just get a set of motors designed for driveway gates? Put them up hi so they're out of the way and they generally have a pretty small profile, as well as all the relevant control systems that should integrate with your home automation.
D
Diggla
Im having a hard time finding out how to get them to work with my insteon setup
jgorm
San Diego
You could use the IO link, some limit switches, and relays.
1419285014190
You should ask over here. These guys are the insteon experts.
http://forum.universal-devices.com/
Dcampbell98xj
You could fab one up out of a liftmaster garage opener with myQ . Then you'd be able to use your phone to open and close it.
RickP
Annapolis, MD
I did, the relay they suggested is around $150 lol.
You got that right - gate opener hardware is expensive!
I think you're on the right track with residential linear openers, as long as your doors aren't too heavy. You might be able to find commercial ones, like they use in supermarkets.
D
Diggla
I m figuring the doors are gonna weigh less than 200 lbs. Got a free over head opener and hv mine so for now gonna try n use 2 overhead garage door openers. 1 for each door mounted parralel to doo jamb. Did a mock up with blocks and hinges. Seems to work. If that doesnt gonna figure out the actuators.
