RobertMo1988
haha nice
Other then buying the spray bomb from snap on, who else has a green spray paint the same as the SO but cheaper?
any paint supply place, Take the PPG code on the label to them and they can mix it
Looking for a cheaper option then $30-40 a can....
Buddy works at a paint supplier said its no issue
Grabber Green (Krylon, Dupli Color, etc.) is similar. Not the same, but close. If you're not putting it right next to Extreme Green, it should be a suitable (cheaper!) option.
I might have gotten a bad can...as I did buy it at a discount outlet...but I bought a can of the DupliColor Grabber Green thinking that...I painted up a HF Screwdriver tray with it, and wow...not even close. much too dark...was my impression.
the color will change with whats under it, usually a good coat of tinted primer will help for sever color changes
10-4!
Next time I'm down at that end of town...i'll see if I cant get something mixed up.
I couldn't see why it couldn't be mixed either, especially when you go to a PPG Shop, and SO provides a PPG Code...If you google up the code, its easy to find and yet, most threads end with "couldn't get it"...
I kinda believed it...when I got the black mixed for my EPIQ work table, it took em a while of clicking to get it...and it ended up being a Ford Black....
My New/Current quest is finding some Vinyl in a color close to Extreme Green...
Can the striking cap prybar handles be replaced? If so do they have a green handle part number?
Can radiator picks and other types of picks have the handles switched, or are they glued on?
No. Not a replacement item from Snap-on
These handles can be swapped with just about anything. of similar size.
nice, 3 sets of adjustables tho? crazy.
Tarpley, what is with all the duplicates and triplicates? I am a little green with envy.
... looks like you are more focused on collecting green tools to display rather than having some green ones that you use...
Exactly....7 ratcheting screwdrivers? That's 6 too many.
Without sounding like an *** it looks like you are more focused on collecting green tools to display rather than having some green ones that you use
