Mr.A
Doing some water line work in my basement. Adding a larger water holding tank and a water filter system. This is on the main water line from my well, I have a submerse well pump. Is this anti drain back valve? and If I relocate it can it be vertical? I am working in a tight spot. Also can a well pump on-off pressure switch be relocated anywhere as long as it is line pressure? Thanks, Ron
