Denwood
Thunder Bay, Ontario, Canada
Never again. My last employer built a new shop and the owner was enamored with the white epoxy floor. It's a horrible work surface. A light oil or coolant spill is invisible and becomes super slippery. I'm kinda surprised nobody had a serious fall.
It does look good and the reflective light is nice, but it's also fragile and slick.
Any smooth floor is dangerous when wet. Your employer should have added some non-skid to the final coat.
kbs2244
Denwood.............
That brings up the question of how slippery is your floor?
I have a brand new floor, no stains, and I like white, but I cannot afford slips and falls.
Denwood
Kbs, not slippery at all. Even after grinding, my rather old floor has lots of surface irregularities. If your floor is very smooth now, you may want to add some non-skid to your final coat.
The Increte stain sealer is 45% solids, so even after 3 coats, deeper pits etc are sealed, but not filled. It's therefore quite fine wet. A 100% solids epoxy would likely completely fill the floor, so would definitely require some care with regard to wet traction.
Dodo
What brand cabinets are those? Cool looking set up.
It's Dura from the UK.
They have a residential line:http://www.duragarages.com/
and a commercial line: http://www.dura.co.uk/
The commercial line is used at many top-end dealerships and even manufacturers.
This pictures from Aston Martin One 77 production plant was my inspiration.
63spyder
Glide Oregon
Never understood this obsession people have with all white. Me I got to have color, and some clutter, makes my life more interesting. Those places just look cold!
Dodo
and which white did you choose? the Porsche or the BMW white? (RAL9016 or 9010?)
despite this, nice!
I went with the same white as in the Aston Martin One 77 plant. It's called "Becker's White" which does not have a RAL color code but the closest is 9016 Traffic White.
The only down side is they charge a fixed "non-standard color" surcharge which is acceptable if you order a lot at one time but too much if you want to add only one piece later on.
Dodo
It's an old age thing I guess. :) I liked clutter and more color when I was younger too. :thumbup:
LegacyIndustrial
deerfield, IL
If you are looking to replicate this look and you want to do it with epoxy/urethane(recommended). Request a "Super Hide White" or "Super White" from your supplier. It will look very similar to the floors in this post. Off-white is the go-to white for most suppliers and although nice will not look as sweet as the floors in this shop. Also... be sure to ask for a Pigmented Urethane Topcoat in the same color as the base epoxy. Extremely durable and will last for years and years without any "ambering".
Trey T
Houston, TX
I can't speak for everybody but from homeowner with residential garage, it's good to have bright color to make the size of the room feel less-small.
kbs2244
Denwood....
So, if I understand it correctly, your floor has a stain that soaks into the existing floor.
It is not a paint that is a film covering the existing floor?
Denwood
Denwood....
Increte refers to the product as a penetrating sealer/stain. Based on MSDS I see titanium oxide (pigment), xylene (solvent) and acrylics. The sealer looks to be acrylic based, and I'm guessing the solvent base penetrates the slab carrying titanium oxide to "stain" it. We selected it over epoxy based on it's breath-ability as well as tolerance for freeze/thaw cycles. It also performed very well despite a pretty cold slab. Looking at their promo literature, it is marketed for use outside. If my slab was kept above freezing, I would have used 100% solids epoxy (better fill properties) for a bit smoother floor. Regardless, the floor surface is more resistance to abuse than I would have guessed. It's pretty clear that the first thin coat did penetrate nicely...but subsequent coats just added color consistently and did some filling. The xylene solvent base definitely was pulled aggressively into the freshly ground slab.
The other aspect of this product I liked is that a touch up top coat is very simple. I have an extra gallon left over just for that purpose if required a few years down the line. We used epoxy over 4500 sq/ft at my business (applied by your's truly) and the chip thing makes the required high wear area re-coat something that will be very hard to blend.
I think the terms stain, solid stain and paint are confusing. I just look at them as paint that is thinned differently :). The Increte sealer/stain has nothing in common with acid stains you see used often on concrete..that's a chemical process and would require sealing after.
polexican23
burbs-Illinois
gladiator just came out with a white/light gray storage cabinet set. Looks awesome, but higher retail cost than the run of the mill black/gray ones
generubin
Of course, Tesla service garages are spotless. There's no oil nor grease involved. And really, service only consists of wiper blades, wiper fluid and maybe disc pads.
ebamba
What are those black mats?
Looks like a tripping hazard to me. Sort of defeats the purpose of a white floor that reflects light under a raised vehicle.
When I was in the Air Force, one of our hangars had painted floors. Light blue IIRC, but the spots where the aircraft were parked for maintenance, were painted white, to reflect light. Floor cleaning was done using a Tennant floor machine.
nickleone
White looks good but not in a area where you will be welding.
A shop I worked in doing fab and welding wanted white walls in the area so you could see better. But the reflections off the walls would mess up seeing thru the welding lens.
We talked the owner into turning around the panels which were dark brown on the other side at table height and above. It cut the reflections down considerably. This was before auto dark helmets. They can be a problem with too much light.
Nick
AHotRod
Weeki Wachee, Florida
My (dusty) White Shop
