compression tester
goldie lox
looking to get a compression tester. wont be using it a lot. thought about getting the hf one but not sure with the reviews. really not looking to get the top of the line but not wanting garbage.
Showkey
"MEMBER EMERITUS"
Wausau WI
If I had to choose one tool I would purchase a cylinder leak down tester instead of a compression gauge. I not purchase either at HF.
Buster21
Idaho
Another vote for Lisle. I have had mine for at least 30 years and it still works perfect !!!!
decableguy2000
I have amiddle of the road with a Craftsman Pro (made by Mityvac), it works well for me mostly on 2 stoke engines and has all the attachments I need.
Jeremy
Shockwave179
WNY
I have an Innova one, seems to work alright. Similar price range to the Lisle that was posted above.
mustangtyson
Richardson, TX
Why would you purchase the leak down tester over the compression tester?
You can test the engine without turning it over. So out of the car or with a dead battery. You can test either at the top of the cylinder or at the bottom. While testing you can see where any gross leakage is happening and can see bubbles or hear the air.
neuralsnafu
Tulsa Ok
I've used the otc tester... worked good. And didn't require any special bs with my euro car...
Sent from my SAMSUNG-SM-G900A using Tapatalk
2oolhound
BC Canada
Make sure it has a pressure release (bleeder) valve so you can start fresh when you want without having to unscrew fittings.
A leak down and compression gauges are 2 different tools. Leakdown uses compressed air through the spark plug holes for readings and compression tester is just that, a reading of actual compression through intake valves (and some valve overlap) that is sealed by the rings and achieved from the stroke of the piston.
MrGiggles
The piston really needs to at TDC or close to it for a conclusive leak down test. Otherwise the valves may be open slightly, rendering the test invalid. Some engines may pass at BDC, others may have a bit of overlap and fail.
The results are more conclusive than a compression test if trying to troubleshoot a misfire. A leak down test not only shows the cylinder's ability to hold pressure, but where it's going if there is a leak, therefore narrowing the problem to a specific component.
A compression test is usually done to evaluate engine condition and to pinpoint a weak cylinder.
Having both tools is best, but you can do more with only a leak down tester than you can with only a compression tester.
royesses
Right. Use the companion cylinder on the valve rocking point if the valve covers are easy to remove. Blow smoke in with the leak down tester to get a visual of whats leaking. Compression tester and leak down tester compliment each other. At least that's how it was when I wrenched for a living.
turfgnome
the best way to explain it is this, a compression tester tells you that you have a problem a leakdown can tell you what the problem is.
racinfarmer
Minnesota/Utah
Do not get the Horrible Freight one. My friend picked one up with the same thought, only use it a few times a year at swap meets to test sleds. We never got any of the 3 to read over 60psi. Put my Lisle on the sleds and it'll at least give me a good idea of that they really have for compression.
spasticone
The OTC kit is the same kit mac and Matco sells. I purchased mine on amazon a few years ago for 50ish bucks when I got into chainsaws. Works great.
Before I bought it, My harbor freight gauge fell apart into a saw and dinged the exhaust port.
neuralsnafu
Tulsa Ok
I just rented it from autozone... thought I had popped a piston, but alas, just a fried headgasket...
