I need to build a 12x12 shed. Started drawing out the plans but ran into an issue with the entry door. I'm going to build the shed as a "mini" pole barn with 4x6 posts. It will have an 8x7 overhead door on the front gable end and a 32" entry door on one of the front corners.
This logically means the in-swing entry door needs to clear under the garage door track. With an 84" tall overhead door and an 81.5" tall entry door, I don't think that will be an issue because of how the track curves up and ends up higher than the 7' height.
However, my design has the entry door close enough to the corner that I'm worried it might hit the curved/radius section of the overhead door track. Basically I have the corner 4x6 post with the 3.5" side facing the gable end but the 2 posts set inwards more (for the overhead door) have the 5.5" side facing the gable end. This helps to space the entry door away from the overhead door a little. I've also designed the rough opening 3" more on that side so I can use 2 2x6 boards to space the door over even farther. I was hoping to use a left hand door (opens into the overhead door).
I've attached some Sketchup views to show what I'm talking about:
1. The door opening: http://i.imgur.com/SBlYIvI.png
2. Inside view: http://i.imgur.com/7g6UjgU.png
3. More of a top view: http://i.imgur.com/BEzrMFC.png
4. A really top view: http://i.imgur.com/5RfpBgg.png
I'm not against centering the entry door between the corner post and middle post, but I'm just trying to avoid losing wall space since the 12x12 is already very small.
Any ideas would be much appreciated!
