ngonerogwu
So picked this thing up off craigslist last night.
1996 Campbell Hausfeld, pump and motor say made in the USA. It's obviously worked hard all it's life. Covered in overspray. It sat for a while apparently, the motor had a ton of wasp nests in it.
I got the guy to turn it on when I got there. Builds to 175 in around 5min, and then shuts off. There is a leak somewhere, you can hear it bleeding off pressure constantly. Pretty sure it's just the line that runs between the pump and the tank, it is bent, looks like something knocked the hell out of it.
The seller was sure that the reed valves were bad and needed to be replaced. Maybe he's right, but i figured if it made pressure and shut off on it's own, they're probably fine. Either way, probably not a difficult fix.
Big thing for me now is getting enough power to it. Data plate says 30a, and 36a. Pretty sure that means use a 50a.
Shop has 40a feeding it from the house, on 8/3. Looks like i'd need to pull new wire out there, 6/3 IIRC (i'll need to check). Swap out the 40a in the main house panel, put in a 50. (This may all be wrong, i have no idea what i'm doing)
Whole lot bigger than my old one.
After a bit of cleaning..
Anyways, gave $300 for it. Probably not a great deal, but I need more air.
