let's see your craftsman block grinders
bagged89s10
CT
The metal gets extremely hot. The plastic cover protects you from burns.
Yeah but it's just ugly.
Darwin protects me from burning my self on metal near a light bulb. :)
Haha
http://www.ebay.com/itm/Craftsman-1...180?pt=LH_DefaultDomain_0&hash=item3f4980a4ac
Only $620 shipped to your door. What a bargain.
I used sarcasm font.
Yeah I saw that, insane!
A 1/4 hp round top just went for $112 on eBay today. Thats a little high too but that's eBay.
~Veeps
bagged89s10
CT
What's the difference in casting marks in bench grinder stands bases. I'm assuming they were made in different factories? Anyone know?
Same on the tops of the stands
~Veeps
bagged89s10
CT
Pickup up a really clean 1/2 HP commercial round top with stand and a tool holder.
Just need to fix the light. This one is the nicest of the 3 I've purchased. Has anyone found any cheap light replacements that match the ones from these grinders?
~Veeps
Here are some more pictures of my 397.19591
It looks like this unit was only used once. I took it off the stand because the stand is getting sent to a fellow GJ member. Which cover is the date under?
~Veeps
McBrownie
Cleveland, OH
~Veeps
I have the same model with no date stamp. Early 70's is my best guess. Last of the round tops. It's a great grinder. Congratulations!
bagged89s10
CT
The one with the wiring diagram. If it's there it's on the other side.
Yes, that's where it was on my other round top right on the bottom of the unit but not on this one or my flat top. Maybe they stopped putting mfg dates after a certain year?
~Veeps
bagged89s10
CT
~Veeps
So I ended up staying up pretty late last night because I was cleaning this thing up. Went to bed at 3am and now up for work m.
Man I'm tired
Took apart and cleaned my 397.19591
I didn't realize this was a 7" model. Ring tested the stones and they are perfect.
It's is such good shape that I'm not going to bother painting it. I just cleaned and waxed it.
Here are the instructions for the grinding attachment. They are not very detailed so I hope I got it installed correctly.
~Veeps
bagged89s10
CT
Man I'm tired
~Veeps
Here is the finished product. I need to find a metal light fixture/cover and need to paint the stand. I lightly oiled up the stand base for now which Is the most rusted on he stand. I have to wait for warm weather. Still in the 30s here in CT. I think it looks real nice.
~Veeps
torqueman2002
SE Michigan
~Veeps
bagged - It looks great! The Wilton in the background sets the stage nicely. :thumbup:
The stand bases tend to get the worst of the rust, but respond well to media blasting.
One piece of advice, the stones show signs of aluminum grinding. They should be ring tested and dressed before use.
Ss95003
Melissa, tx
Looks pretty slick Bagged. That Grinder looks nice on that stand. great combo.
I liked the idea of the rubber feet someone posted couple pages back. definitely going to barrow that idea.
bagged89s10
CT
^ Nice score and grinder (love the round top with crown to boot).:thumbup:
Thanks tx
It's funny how underneath the base there is almost no rust.
I think a wire wheel will take care of it. I don't have a media blaster and trying to keep my cost down. How much do you think most places charge to blast something like this stand?
Yes the left stone needs to be dressed? Any recommendations on what tool to buy?. I know HF sells one but I don't want my stones ruined. I did ring tested them and they sound beautiful.
Yes I'm putting some of those or similar feet in mine as well.
~Veeps
exmaxima1
Midwest
The best dresser would be a single point diamond type as it will true up the wheel as well as "dress" it. You can find them on fleabay for around $10.
torqueman2002
SE Michigan
My comments follow in Blue.
Yes, some times I don't even need to blast them much more than to remove minor rust in the corners. I suppose it's from all the **** that is dropped/splashed on their top sides? :dunno:
That works, just takes a bit longer.
I haven't had any experience with paying someone.
I have been adding $15 for the stands I've sold recently, if the buyer chooses.
It's not a well paid job, I have spent 1 - 3 hours cleaning them up.
:p123
I have this 1, I've used it for about 6 months and done about a dozen stones.
http://www.amazon.com/dp/B00B10LM6O/?tag=atomicindus08-20
~Veeps
exmaxima1
Midwest
Are you talking about the same type that TORUEMAN shared?
It's like the SECOND diamond tool he posted (above).
They come in several styles, long and stubby, and both are intended to be mounted into a holder for use. Typical holder for a surface grinder would be a block of steel that sticks to the magnetic chuck for dressing the wheel. Another typical holder is simply a thick bar to act as a handle as you shape/true the wheel by hand.
I recently bought a few stubbies and made my own holder for dressing bench grinder wheels. I had seen an image somewhere (can't recall where) and emulated the design. I have a box of old sewing machine parts and found a usable fine-thread tube in which to mount the diamond "bit". I drilled & tapped a hole in the bit to fix it to the tube. I used a scrap of Delrin plastic (similar to nylon and easy to machine) for the block. I have no idea what the thread size was on the tube, but I ground a few notches on the tube OD and it cut it's own threads into the Delrin block. I added a series of threaded holes for the guide bar on the block.
In use you adjust the block to fit on your grinder's steady rest, and simply move it across the wheel face to true it up.
mtwaterguy
Here's the 1/2 HP that showed up Monday.
Here's the 1HP that arrived today.
Now I just need to figure out where all this goes :lol_hitti
bagged89s10
CT
Nice additon? :thumbup: it's like me when I was trying to figure out how to attach the tool holder to mine.
~Veeps
drivesitfar
MT: i might have saved a picture of that 1 HP grinder with all the attachments on it if you need one. or i think one of the members posted it on this thread just before you bought it. very nice duo and can't wait to see how you line them up with different wheels.
ALL: i have a different diamond truing tool that is more like a piece of 1/2 inch square stock with a diamond in the end of it. probably a 1/16 or less caret or maybe it's a full caret imbedded inside the stock.:eyecrazy:
bagged89s10
CT
Yea I need one of those stubby guys with the adjustable block. I saw a guy on you tube using it but didn't get a chance to look them up. Good idea to make your own.
~Veeps
jakemac
New England
Sez the guy who built the robot in the other corner of the arena.
SUNDAY, SUNDAY, SUNDAY !!!
Blockmeister -vs- MegaBlock
:boxer: :Mr.T: :see:
iceman510
This place is just bad. I am in the market for a drill press and maybe a second grinder, and now I will of course settle for nothing less than something old and vintage because of all you Craftsmen hoarders!:lol:
bagged89s10
CT
Very bad! Very bad.! I blame garage journal for my old vintage tool problem. :thumbup:
~Veeps
