Resize jumbo picture attempt
Shadowdog500
Down the shore
Not resized
15vxj
theoldwizard1
SE MI
How to resize and post without having a hosting site !
  • Windows Paint has simple, easy to use resize capability. First, you need the file on your PC. Copy it to a second file (so you don't mess up the first one).
  • RIGHT CLICK the file name and use "Open with ..." to open it with Paint.
  • Resize is near the top to the left.
  • The amount you have to resize depends on how big the original was. I usually start with 66%. If that does not work, click UNDO and try a smaller number (the example was 25% of the original). Repeat until you get the desirable results.
  • Attach it to your post using "Manage attachments" (below your editing window).
  • Click "Preview Post"
  • Place your mouse pointer on the thumbnail and RIGHT CLICK. Click "Open image in new tab".
  • In that new that, select and copy the URL.
  • Use the "mountain" icon on the second row of the editing window menu and paste in that URL.
Cropping down to the "relevant" part is nice also !
Shadowdog500
Down the shore
Get a free copy of PhotoScape and easily resize to 640x480 on your own computer, then post as an attachment here, or place it on a hosting site and point to it with a link.
http://www.photoscape.org/ps/main/index.php
Thanks, but I was looking for a way to resize linked photos from the web without having to pull them onto my computer.
Vbulliten used to let you put the desired image size on the first box. I was trying to see if the current host has that feature. If it does , I haven't found it.
Thanks,
Chris
theoldwizard1
SE MI
Vbulliten used to let you put the desired image size on the first box. I was trying to see if the current host has that feature. If it does , I haven't found it.[/QUOTE]
Vbulletin DOES allow this [I](and I think you had the correct syntax)[/I], but it is either in a latter version than what Atomic Industries hosting site is running, or it is "turned off".
Pain in the **** doing it the other way, but I do it, if the pic is important to the thread.
DenisG
Milwaukee
From one of your attempts, if I go to
http://imageshack.com/i/15vxj
I can see the picture in your album.
If I right click on the picture and select "Copy Image Location", then open up a new Tab in my browser and paste the copied image location:
http://imagizer.imageshack.us/v2/706x530q90/41/vx.jpg
I see your picture alone (not in your imageshack album).
In the image location address there is "706x530". That is the pixel size (which is fine for posting here). I can also change those numbers to "640x480" to change the picture size directly.
