23 CHIEF
Can I put two 12-2 cables under these staples
That particular staple is designed for one cable.
I have to believe that is correct because if you drive the nails too hard it will snap the plastic. But, the nails look plenty long enough so could you stack 2 with a cable in each? Probably not the fastest way to staple off your romex.
My understanding is if it doesn't list that more than one cable can be held then the staple is only meant for one cable.
