Painting 3,500 sq ft Rust Bullet.
Skip Fix
Katy,Texas
Painted the new shop floor this weekend. Still a little sore!
First day 10 man hours(had a helper) and 9 gallons.
Second day second coat 6 1/2 man hours and 5.5-6 gallons.
Second coat went on easier as you did not have cover every dimple in the floor for coverage. Down side same color do harder to tell where you had painted.
Stuff is hard as a rock! Where the concrete is rough it stayed rough but the smooth areas may be a little too smooth and end up slick.
Used an extra deep roller pan that held almost 1/2 gallon at a time so less filling the tray to slosh it all over-stuff id bad *** and sticks to every thing hard.
Garage Flooring
Grand Junction, CO
You rock! We can't wait to see some pictures!
Skip Fix
Katy,Texas
The wind picked up and since it's spring the trees are blowing all kinds of pollen fluff around!
First day was not as humid and even after 5 hours the first stuff down was still tacky, second say at 3 1/2 hours the first stuff was not tacky anymore.
Garage Flooring
Grand Junction, CO
Good idea to keep it all shut! Remember nothing on the floor for 72 hours from the last area you rolled.
Skip Fix
Katy,Texas
I'll get pictures this weekend. Didn't want to get paint fingerprints on the Nikon since that stuff never comes off!
Skip Fix
Katy,Texas
Justin if I find it is too slick let's say in a year what is the easiest way to add some traction?
I would say a squeegee would leave it too thick or uneven thickness or waste a lot and it is not cheap if you are doing a big surface.
Garage Flooring
Grand Junction, CO
Sorry. 4 day vacation and we were driving through mountains. Rough it up with 120 grit sand paper, clean and go.
Skip Fix
Katy,Texas
Ok here is some before and some after painting.
First two with dog before.
Skip Fix
Katy,Texas
Now if the road/driveway guy had just shown up yesterday to get a quote! Plan is crushed concrete will be about 600 ft.
Garage Flooring
Grand Junction, CO
One of the most frustrating things dealing with projects is when people do not do what they said they would. Sometimes people act like they don't want your business. Dives me crazy.
Skip Fix
Katy,Texas
Justin what e mail for pictures?
Shop is 50x70', three 14' roll up doors, one regular door, 16' eave height so I can put a lift in. It was not that expensive to go "up".
Here is a picture of the property and the general long term plans-house barn. Big pecan trees drop big limbs so tried to put everything out of fall areas! I've worn out one chain saw already and have a big stack of cut wood.
dmcintosh
Smyrna, DE
Floor looks great. I just ordered some Rust Bullet for my new garage. Was wondering what the best prep is for new/fresh concrete. My floor was pour just about a month ago. I know that Rust Bullet doesn't require extensive prep like epoxy would, but it is necessary to clean the new concrete before applying?
Garage Flooring
Grand Junction, CO
Yes. I would power wash or scrub the floor first. The. Let it dry. Then coat. Make sure that slab is cured. Rule of thumb is 30 days but pays to check.
