Tools from the old world
rice rocket
cool ! How do you like it ? :)
It's pretty nice. I bought it mostly because I need the autoclean, and the Festool autoclean vac was $300 more. :scared:
Build quality is nice, but some things are still nicer on my Festool. i.e. the cable supplied is only 16AWG wire, which should be only good for about 10 amps. When you add a tool to the socket in the front, you could probably pull close to 15 amps. The Festool came with a 12AWG I think, which should be good up to 20 amps. The cable holder is easier on the Festool as well, but not a big deal.
It does seem quieter than the Festool though, and the double walled tub should be nice for durability.
jobo1004
Kansas City, MO
I love following this thread. Here's what I've got: Felo, Knipex, NWS, Wiha and some GripOn.
bahcoswed
Sweden
ImageUploadedByTapatalk1428085184.740680.jpg Does anyone know if there are any difference between Sandvik Belzer 1952m and Bahco 1952m? Sandvik are a little bit slimmer and some sizes are longer! Bahco are the newer version of 1952m, but i think sandvik are much better in strenght and holds up better! So is anyone sitting on more knowledge about these very nice and thin wrenches? Do not mix up Belzer 1952m with sandvik belzer 1952m! These wrenches are exactly the same as Bahco 1952m.
Monte
Germany
Very, very nice! :bowdown::thumbup:
Do you own a sandblaster or did you take it somewhere?
i bought one of these cheap sandblast cabinets from ebay for 80 bucks or so.
What do you mean "new"? Is there "old" batteries too?
I just won this 4Ah battery on ebay. Is it new or old? Differences? :headscrat
the old ones were 1.5AH, the new ones are 2.0AH and the newest ones are 2.5AH. 4.0AH is their large capacity battery right now. Who knows maybe they´ll make a 5.0AH battery too. :) But i think the 4.0AH battery is sufficient enough.
Nice restoration!:thumbup:
And as you've got this far, those PB doohickies are in fact Fondue forks....
cool !!! :bowdown:
did you already try it with a tool ? Does the fuse blow ?
Never heard of problems yet.
btw. here´s a topic about Starmix vacs and how to modify them so they can carry a systainer:
http://mafell-users-forum.freeforums.net/thread/55/starmix-vacs
btw. just found another Starmix customer: Ermator from Sweden:
nice collection of quality tools ! I even see a NWS counterpart from Vice Grip :)
^beautiful
nice work monte
thanks !
Made in Germany vs. not made in Germany :D
bahcoswed
Sweden
cool !!! :bowdown:
thanks !
Yes i know that:) But they are not made in asia anyway...argentina isnt so bad:( Or WAS, these days i dont know.
Vidar Wulff
Harstad,Norway
does it say germany on the sandvik wrench if you twist it 180 degrees? Sandvik moved production to the old bahco factory in argentina,i am not sure exactly when they stopped making the tools in germany.
My Sandvik belzer 111 wrenches look similar,but there are small differences between the german vs argentina made wrenches.
bahcoswed
Sweden
I was so sure on the coo! I just checked my sandvik belzer 1952m(only have 3pc with 10,15 and 21mm). I thou have a set from 6-30mm with bahco 1952m! The only wrench with Germany on it is the 21mm wrench! The 10mm is missing coo but look like a german made! But the 15mm also without coo look like a bahco, same shape,same thickness on the box end and open end and the same length! Bahco has a bigger offset than sandvik on both argentina and germany made ones! Funny thing, the argentina made 15mm wrench look precisely like a bahco, but the 10mm Arg.made look like a german!
rice rocket
I haven't tripped a breaker/fuse yet, but I believe the vac is 11 amps (at least on the Metabo version, the knob goes to 11 :) ), that's about the limit of 16AWG. My Festool sander is 720W or 6A, that would put it at 17A at full draw. :eek:
Yeah, thanks for linking that thread. I need to read that over again and figure out the docking situation.
I might just end up getting a cart for my systainers though, I've been looking at the Fetra Paketroller 1732.
I'm not sure who originated this design, but it's been copied a million times it seems if you look on eBay or Amazon under Magna Cart. Petra is one of the few that makes it in Germany.
Also, this came in.
Monte
Germany
i dunno....there is only one real coo for Belzer tools :D
Let me know if you have any problems since i´m very interested in getting a Starmix vac in the future !
What about the SysRoll
https://www.festoolusa.com/power-to...rt/sysroll-systainer-and-storage-dolly-498660
or Systainer cart ?
https://www.festoolusa.com/power-tool-accessories/storage-systems/sysport-cart/systainer-cart-495020
Also, this came in.
nice machine ! So you´re doing stainless steel work ?
Systainer collection grows more diverse...
nice !! btw. do you have some more pics of your new vacuum ? :drool:
Spax wood screw assortment
content:
screws made in.....:
box made by Raaco in:
And a lonely Spax Hi.Force screw
rice rocket
or Systainer cart ?
Heh, not sure there's much to show.
Cord management is a bit fussy. I'm going to look into that Mafell/Metabo topper conversion, which has a cord wrap and should accommodate the hose a little easier.
As for systainer transport, the SYS Roll doesn't fold up at all, the footprint is what it is, which is really inconvenient for transport unless you have a work van. I think I can add some tabs to the folding cart to stabilize and it should be fine.
The Metabo burnisher is currently for refinishing my appliances, hopefully I'll be getting into more furniture fabrication and will be using it more. :thumbup:
Got some Wera Hex Plus in, made in the Czech Republic, like most of Wera's stuff.
(borrowed pic)
zaboravi
Bosnia
@Monte, do you know witch models of Bosch Schlagbohrmaschinen are made in Germany or made in Switzerland? Thanks
zaboravi
Bosnia
I'm not Monte ;) but.............
GSB 21-2 Re
GSB 21-2 RCT
GSB 162-2 RE
are Made in Switzerland
Thanks... :thumbup: What do you know about GSB 18 RE model? Man told me that is swiss made and I cant find it on Bosch website? Any opinions about Russian made Bosch? Thanks a lot :beer::beer::beer:
Blöckw@rt
Germany
I know that the GSB 19-2 RE is made in Russia and I would suspect the GSB 18 too, but I can't say anything about the quality.
But I do not think that the russian made impact drills are really bad.
Monte
Germany
Monte what's the backstory for spax?
Spax produces screws since 1823 in Germany. "Spax" is the synonym for woodworking screws in Germany. So if you go to a store and ask for Spax screws everybody knows what you mean even if they don´t carry Spax (which is seldom). So basically they´re good screws for woodworking. :)
They also manufacture other screws like wheels bolts and cylinder head bolts etc. for major car manufacturers like Audi, Porsche and Bentley. They also own the Trufast brand from the US.
Yeah the parts storage could be better...i think that will be solved with the next generation. yes you´re right, i thought you can fold the Sys roll...indeed thats inconvenient.....the prices are also a bit :(.......
Hey cool maybe you can show some pics when you use the burnishing machine !
here: :)
GSB 21-2 Re
GSB 21-2 RCT
GSB 162-2 RE
you also could check out Metabo..........
Monte, I sent you a PM about a Gedore ratchet, Please check!
ok :)
ash95608
carmichael, CA
I love spax screws, I use them all the time. Homedepot has them now, on the package they say made in Germany or USA. I believe they are setting up a actual production plant here in the US.
Patrick Boyle
Western Montana
I'm gonna throw in another recommendation for Spax. Anyone who hasn't use them needs to give them a shot. I'm SO glad they made their way into the US market, they're all I use anymore.
jetdawg
LA
Thanks for the information sir.
Monte
Germany
Heco screws are pretty good too imho
(Heco Unix)
http://www.provenbuildingsupplies.com/heco.php#unixBubble
www.heco-schrauben.de
<iframe width="560" height="315" src="https://www.youtube.com/embed/uLBQYotMviw" frameborder="0" allowfullscreen></iframe>
Metabo angle grinders vs. the competition: :)
<iframe width="640" height="360" src="https://www.youtube.com/embed/OUZVrmL8Rp8" frameborder="0" allowfullscreen></iframe>
dutchgray
Dorset. England.
Monte
Can you add direct links to youtube in future, the embedded videos don't work on my phone and its annoying having to click quote to grab the vid ID.
Metabo grinder looks like it can take some serious use, might have to get one.
Lofthouse
New Welding Cable, 9"Cutting Disk, TIG Welding Rod
Monte
Germany
Monte
ok, i try to remember it :)
the new Fein "ErgoGrip" angle grinders...
<iframe width="640" height="360" src="https://www.youtube.com/embed/G8pIHm8S8i4" frameborder="0" allowfullscreen></iframe>
...and die grinders:
<iframe width="640" height="360" src="https://www.youtube.com/embed/3tswSgWQ6sA" frameborder="0" allowfullscreen></iframe>
Wiha corporate video 2015:
<iframe width="640" height="360" src="https://www.youtube.com/embed/OBNEJE0gD8k" frameborder="0" allowfullscreen></iframe>
rice rocket
I have a Fein WSS14-125 angle grinder that I'm not too fond of. Ergonomics seem weird, but it's also my newest grinder so maybe I'm not used to it.
I just ordered a Metabo WEPBA14-125 yesterday, should get it on Monday, and I'll have a little grinder shootout.:willy_nil
<iframe width="853" height="480" src="https://www.youtube.com/embed/u8SIXxyhz_A" frameborder="0" allowfullscreen></iframe>
LG63
Looking forward to the comparo. I have the Metabo 6" with autobalancer that I use exclusively with a cut off wheel. Very smooth just like in the video. I never felt the need for a brake on a grinder. (unlike a skilsaw) Seems like the brake would tend to make the quicknut loosen, also another component to wear out.
