KMScott
KMS - the more I am learning the more I see I totally lucked out with the Prentiss 98 slide not being cracked, although some reading indicates it is purely cosmetic.
Jeff
Not so if you use the full extent of your vise, the crack splits out the square slider so much that on some vises like my 98 I have to C-clamp it to remove the Dynamic Jaw Support. This means the slider is rubbing the Static Jaw Support every time it is moved. Maybe drilling a hole will stop the casting knit line from continuing but the best fix is either brazing or welding and keep the crack from growing. The Reed I showed on the last page has really split and needs repairing.
figuring out how close Nottinghamshire is to a container port......
Ya think?
