The VISES of Garage Journal
KMScott
KMS - the more I am learning the more I see I totally lucked out with the Prentiss 98 slide not being cracked, although some reading indicates it is purely cosmetic.
Jeff
Not so if you use the full extent of your vise, the crack splits out the square slider so much that on some vises like my 98 I have to C-clamp it to remove the Dynamic Jaw Support. This means the slider is rubbing the Static Jaw Support every time it is moved. Maybe drilling a hole will stop the casting knit line from continuing but the best fix is either brazing or welding and keep the crack from growing. The Reed I showed on the last page has really split and needs repairing.
trijeff
Northern Cali
Jeff
A-ha! Makes sense. Did I read that correctly that you have a 98?? I knew about your 58 but didn't know you may have the full set :bowdown:
bigcaddy
Orange County/ San Fernando Valley
Welcome to the gang, 02superduty - You've got (and in some cases, had) some really nice hardware there!! Do you have any of the Reed combination vises? I hear the 2 thru 4C are some of the nicest vises ever made. For a laugh, imagine this 140lb guy having to move the swivel version of the 58 (a 98) without help of a forklift or anyone else.:Freak:
A 2C is my everyday vise and am currently looking to upgrade to a 4C they are definitely stout and take a beating without so much as a flinch:thumbup:
topop101
NW Missouri
Not only the Prentiss's have crack issues, these two Reeds I pulled out have the crack issue too. I am going to line these guys up with the Prentiss's one day and braze them all. I'll be a pro when I am done.
Let me know when you are ready, I have a 105 reed the same way
ShadowRuleZ
Detroit
shadow - nice Reed! That is one of the transition models where it has the new oil holes (there is one in the slide, too, right?) but the old meatball spindle and four-hole base. Crisp looking jaws and slide lines, looks like that thing sat unused for quite awhile. Great score, do you plan on cleaning it up at all or going directly into service?
I don't remember seeing one, I'll have to look again. No real plans for it but couldn't leave it when it was only $25.
zkling
Jeff
Reed's higher tolerances become a problem here. A little while back I went to look at a 4" reed, ended up having a good 4" crack going up the back of the slide. You couldn't open it more than half way. When the split happens residual stresses from casting/machining in the slide cause it to spread further.
CwazyWabbit
Surrey, UK
Interesting, thanks for the pics. I think that is one of the earlier/nicer ones. With the peened over handle ends and fully enclosed base.
Certainly seems a nice build quality, do they all have Poland in big letters on the side? I don't recall seeing that on other pictures I've seen.
CwazyWabbit
Surrey, UK
Probably a question more for the UK and Canadian vice addicts here. Anyone aware of these models of Record vices?
I've seen the 34-36's but not these, advert is from the 1970's.
CwazyWabbit
Surrey, UK
:drool: figuring out how close Nottinghamshire is to a container port......
The price is high....I've asked for more photos....he hasn't replied to me either.
As Yoda said, "There is another"....
Last year, this appeared and vanished on ebay.co.uk for 350GBP
The one in front is a 6" Record 112 vice for purposes of scale...when a Coke can just isn't enough.
It was IDed as a 518, but Record didn't make a 518....
No. 518 1/2 : 8 1/2 inch jaw, 12 inch opening, 5 1/2 inch depth, weight: 265 lb.
15 pounds heavier than the No.49....
So, they are out there, in the fog....... Hiding behind the unicorn
Thrumcap
:canadian:
Today I discovered there was a No 518 .... and it looks like there was a lot less meat on the bone in the 70's
For comparison the 1964 advert (from a 1968 reprint)
FMC1959
Montreal, Canada / Upstate NY
Interesting, I have seen other Record models that 1" size bigger vise adds maybe 10-20 lbs. In this case between a 518 & a 518 1/2, that extra 1/2" on the jaws is 82 lbs more vise!
CwazyWabbit
Surrey, UK
I'm wondering if the vices went on a diet between the 1964/68 advert and the 1971/72 advert? The 516 remained the same weight though ..... however the 518 is lighter than the 517
Craptain
Tampa Bay FL
My 6" vise does not have Poland on it. Not the best pictures but all I have on my phone.
Sent from my LG-D801 using Tapatalk
vintage nut
west coast of canada
Those are such cool looking vises! Am I right in understanding that they have an adjustable gib like a milling machine table? If so that's a very interesting design
you can never have too many tools
drivesitfar
CW: I don't recall seeing Poland on the side of any of the Bison or FPU vices. here's a couple pictures of my 3 inch FPU and i can't remember exactly where i bought it. i do remember it came with a workbench and from one of my older clients a few years ago and when i handed it to Balane to tune up i remember him saying it was one of the nicest and smoothest working vices he'd worked on.
Best of luck finding the Record 518.5. at 260 pounds would it be your biggest vice?
Zoomie: thanks for picture of 8 inch Wilton with the baby on it's back. funny a guy with Nuts as his handle is saying you have a vice for vises. keep posting pictures of your sea of Tetanus as you can and those Reed C series vises you just restored look great.
Nuts: if i remember correctly you have a different type of steel addiction that are a lot bigger than vises and they have wheels on them.
Craptain
Tampa Bay FL
Yes. They do have adjustable gib. One of, if not the nicest vises I have ever used.
Lu-Max
Roughly what year would you say this Wilton is from?
vintage nut
They sound like it! I know bison lathe chucks are very good, so I'm not surprised their vises are. Definitely have to grab it if I ever see one!
vintage nut
Ahh yes, here's that little toolmakers vise I mentioned. My dad is currently making some brass jaws for it. This was the first year exam project for an apprentice machinist at the local navy dockyard. Kinda a cool little thing. Probably going to be used for small parts on the drill press.
Sitting on a 4" record. Very nicely made little project!
