Electrical problem need help on... I'm lost
justsam
Penngrove, California
That looks right now. Hot lead should be on black common of 3 way.
One note, when wrapping wire around a screw, always loop it in a way that tightening the screw tends to close the loop, as opposed to open.
Opps Wylie beat me to it!
C96
Glad to see you got it worked out! :beer:
Also, not to be nit-picky, but as a future reference and I realize the old ones don’t have them, the ground screws are required to be used when retrofitting switches when there is a ground wire present inside the box.
Lol…Yep, he does that a lot…smart sombitch that Wylie :thumbup:
wyliesdiesels
Modesto, CA
Gosh that was a cluster **** of wiring! It makes sense now why it didnt work without the fixture!
Im glad we kept on it. When i took a long look at the pic, it didnt look right. At a quick glance, u might not notice the issue!
Yeah i like to be quick on the draw with my 10 shooter(fingers)...
Honestly i like these threads cause it keeps me sharp on my visual troubleshooting skills. Helps when im doing service calls in the field.
T
taumac
Brooksville, Fl
Ok myself I don't think a did anything different than way it was other than the back stabbing. What's different? I looked at pics and I thought I saw 2 hots on the 3 way so I freaked out.
T
taumac
Brooksville, Fl
One other question I'm working on my house too and hooking up some outlets in the garage by my sink.
One to left is a existing GFCI and want few more outlets. Here's my box opened.
If I can I would like to have 3 more outlets (but 1 more on other side of sink would work ) on this and want them all tied to the GFCI. What's the best way to add them? Do I connect off the outlet cause there looks to be other set of holes to add wire or do I tie in at wire nuts?
Mustang51js
Haskell nj
Run a tail off the load side of gfi and wire nut the old wire and the new wire to it
Edit, I see you have tails already so just wire nut them in,will prob need bigger nuts though
T
taumac
Brooksville, Fl
Ok cool will do that.
And thank you all for the help. I can usually do wiring myself. Many times I open a box and sit there and trying to figure out "what are they trying to accomplish" with this. I have no diagram and work is done by a electrician 25+ years. It all accomplishes same task but different methods.
I still don't know why exactly why having dining room fixture install cause a light powered upstream not to work properly?
C96
In this picture it looks as though the black wire directly behind the other black wire under the wire nut has had an overheating issue. The insulation looks melted :headscrat
T
taumac
Brooksville, Fl
Interesting? They where heavy gauge wire as can tell from the neutrals. I didn't notice a issue with wire when working with them.
Mustang51js
Haskell nj
Don't think it's melted, prob just got smashed into back of box,usually when something is overheated you see it on the ends more,not in the middle of the wire
