I don't think I can go wrong for free.
Very little downside to 'free'!
If nothing else, you're building an inventory of parts for use, sale, or trade.
From what I can see in the pics get everything you can from there. Looks to be some interesting stuff.
As already mentioned, the teeth on the gear for raise and tilt is stripped on a good number of these saws. The other issue I see a lot is that the arbor is smaller than a typical blade. You need an insert(I get them at HF) to make it work properly. Going by memory, I think the arbor is 1/2" and most blades are 5/8". I've "fixed" a lot of these saws that had this issue, the PO couldn't figure out why the saw wanted to walk across the floor.
Whether the tilt gear is good or not, it will still be a nice little saw for 90 degree cuts and rips.
BTW, I have a spare fence (and a few other parts) for that model if you need it.
Veeps, looks great! You said it, cant beat free. Any luck on any of the rest of his items?
)I don't have any pictures (or the right set-up to take pictures of), but the majority of the weight of the motor rests on a bracket shaped like a long C that's laying on it's back. That pin is just there for alignment of the motor as the blade is tilted. The pin slides the motor on it's mount so that the belt doesn't come out of alignment as it's twisted by the tilting blade arbor.
Most of the time that pin is missing or broken off.
The belt tension is created by the motor hanging out the back like a drunken party girl counter-balancing a catamaran off the Florida Keys.
(OK, so maybe I didn't describe it too clearly, but I had fun trying)
EDIT :
I see the motor mount in the last picture of the first post, so you should have everything you need to get going once you get a belt. You might want to clean up the sliding bar on the motor mount to make sure that the motor can move easily as the blade is tilted.
the one l had, came with these 2 bars extending horizontally from the ft. and back of the table. Ant the stamped steel extension wing slid along the bars, and you locked it down where you wanted it.
I think that might be intended to be a hydraulic pump, not a water pump. Here's the patent.
http://www.google.com/patents/US1976227
